MacBook Pro A1706 - 820-00239 - No backlight
  • ryogadan78
    • Nov 2021
    • 66
    • Italia
    Detached corrected chip, and soldered new chipClick image for larger version
Name:	WhatsApp Image 2024-03-04 at 12.52.54.jpg
    Old damaged chip
Name:	WhatsApp Image 2024-03-04 at 12.56.29.jpg
    New chip
    Should I do some testing before retrying the mainboard with all the connections?
    • mon2
      • Dec 2019
      • 14663
      Looks very clean. Proceed to test again.
      • ryogadan78
        • Nov 2021
        • 66
        • Italia
        Hi mon2, really thanks. Everything works like a charm
Name:	WhatsApp Image 2024-03-05 at 09.42.16.jpg
        • Comp_Pro
          No Backlight Macbook A1990 820-01041
          by Comp_Pro
          Hello all,
          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
          Tests performed:
          There is no backlight even with a good screen.
          Backlight IC is receiving the correct support voltages.
          Fuse F8400 ok
          Current sense resistor R8400 ok
          Backlight IC is receiving 3.3V on enable pin.
          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
          Backlight IC receiving 5V from PP5V_G3S
          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
          05-06-2024, 10:23 PM
        • Baspotv
          Macbook Pro A1706 no backlight and not booting up
          by Baspotv
          So recently I got this macbook from a friend of mine. He went to the apple store after his mac did not boot up anymore and they told him that the mac has got a cpu issue. After that he asked me if I could take a look at it and so I did. I got the schematic and boardview from this forum so I started looking for an issue and the only thing I've found is that the capacitors on Page 10 (C1000, C1001,...) all are shorted to ground, so after that I soldered 2 wires to C10G0 and put 2V onto it. After closer Inspection under the Thermal cam the only thing that got hot was the CPU. I followed the path...
          10-18-2024, 02:41 PM
        • Constantinos
          Macbook Pro A2442 820-02098 No image but has backlight
          by Constantinos
          Hi all
          I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
          He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
          Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
          Obviously, he decided against this and gave it to me so that I could have a crack at it.
          From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
          08-24-2024, 09:48 AM
        • francescoranchi
          MacBook Pro A1909 LCD (no backlight)
          by francescoranchi
          Hello Everyone,
          I'm looking at purchasing a used LCD from ebay for my macbook A1990 2018 15inch which LCD I cracked. Since new / used but working displays cost around 500$ , I found a Grade A+ LCD display for A1990 which has a good price of 110$ but has no backlight.
          I would need just to make sure that what I know/my reasoning is correct:
          - No backlight means flexgate issue, therefore changingthe flexcable would be enough (I can microsolder to fix the flexgate problem, done it a few times already)
          - Seller confirmed its a LCD issue, and not an issue with the...
          12-04-2023, 06:46 AM
        • tommy97
          Apple MacBook A2337 - No backlight
          by tommy97
          Hi guys, I've got MacBook Air a2337 with no backlight. Once while testing it displayed with the backlight, however after restart problem come back.
          The laptop was tested with fully working screen.
          PP5v_BKLT_A/B 5V
          PP5v_BKLT_D 5V
          PP5V_S2 5V
          PP5V_SW_LCD 0.4V
          P5VS2_PWR_EN 1.8V
          P5VS2_BST_R 8V
          P5VS2_SW 5V
          PPBUS_5VS2_VIN 5V
          PPVOUT_LCDBKLT - Doesn't short 0V
          FP800 - Both sides 12v
          BKLT_EN_R & BL_PWR_EN - around 1.8v
          LP800 0.014V On both sides (should be 12? / no short)
          UC300 & UP800 Replaced...
          12-02-2024, 08:26 AM
