A1708 Touch pad with broken components.
  • gergely
    • Oct 2017
    • 25
    • Spain
    Hi! Can someone please help me with what kind of resistor values i need for a few missing components on the A1708 touch pad. Thanks
  • mon2
    • 14673
    Track pads are usually just replaced due to lack of schematics for these devices.
    • gergely
      • Oct 2017
      • 25
      • Spain
      nah. fixed it. 0 ohm resistors
      • Sam Scarbo
        Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
        by Sam Scarbo
        My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
        I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
        If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
        See the attached two pictures of the small...
        09-18-2024, 08:29 AM
      • trepachka
        Converting HP EliteBook 840 G7 non-touch to touch if possible
        by trepachka
        I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
        The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
        I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
        04-27-2024, 11:15 PM
      • Prott
        Surface Pro 4/5 - no touch after LCD change
        by Prott
        I have a question that's driving me a bit nuts recently.
        Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
        - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
        - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
        01-25-2023, 12:42 PM
      • mengpo
        Siemens RVS21.831, Looking for References, Models, and Values of These Components
        by mengpo
        Following a short circuit on the controller board of my heat pump, I'm looking to replace the components shown in the photos. All I know is that they are diodes (but I'm not sure what type), and I haven't been able to find their equivalents.
        The one on the left says: 15A 5BA
        The one on the right says: DTZ S47 or DTZ 547
        Does anyone know how to identify them?
        Thank you very much for your help!
        FYI, the card is a siemens RVS21.831
        02-15-2025, 10:50 AM
      • labello
        Tv Smarttech 43 smd components broken identification
        by labello
        Hello everyone i can't find anything about this smd because it's completely destroyed, no mark on it, the tv turn on backlight is on
        but no picture, I check voltage on t-con board any voltage, the fuse is good. I don't know if i can replace something similar but I don't know what. Thank you so much for the reply...
        01-17-2025, 03:39 AM
