A2338 - 820-02020 5V 0.370A, 20V 0.018A
  • GRrHaG
    • Oct 2023
    • 7
    • France
    Hi all, I am working on a MacBook logic board # 820-02020. It is stuck on 5v
    PPVBUS_USBC0 = 5V
    PPVBUS_USBC1 = 0V
    PPDCIN_USBC_AON =5V
    UF500 CD3217B12 :
    PP3V3_UPC1_LDO = 3.26V
    PP1V5_UPC1_LDO_CORE = 1.56V
    UF400 CD3217B12 :
    PP3V3_UPC0_LDO = 3.26V
    PP1V5_UPC0_LDO_CORE = 1.56V
    PPBUS_AON = 12.19V
    If i plug a second USBC on the other port , no matter which one, PPVBUS_USBC0 = 5V, PPVBUS_USBC1 = 20.1V, PP3V3_UPC1_LDO = 3.26V, PP1V5_UPC1_LDO_CORE = 1.56V, PPDCIN_USBC_AON =5V
    What is causing all this 20V not to come through. Any help will be greatly appreciated. Thanks in advance.​
  • mon2
    • 14698
    First, try to use ipa (alcohol) & Q-tip / cotton swab to clean up the USB Type connector contacts. Often some contamination / cat puke is blocking a proper connection for communication. There is a single wire communication on each side of the USB Type C connector with net name of CCx (CC1 / CC2). Each is used to extract details from your power adapter and then the logic board will select the optimal charge voltage and current pair (power delivery contract). You do show 20V in one of the permutations of the tests so there is hope.
    After the above -> remove all power / disconnect the battery -> meter in DIODE mode -> red meter probe to ground (yes ground); black meter probe onto the CCx pin that is working -> note the DIODE mode reading value -> repeat to test the CCx pins on the other side of this same connector that is not working. What is the measurement? Repeat for the other side of the logic board.
    • GRrHaG
      • Oct 2023
      • 7
      • France
      Thanks for repply
      USBC0_CC1 = 0.597 on CF413
      USBC0_CC2 = 0.597 on CF414
      USBC1_CC1 = 0.597 on CF513
      USBC1_CC2 = 0.597 on CF514
      Mesure on usb c contact
      USB0 :
      CC1 = 0,597
      CC2 = 0,597
      USB1 :
      CC1 = 0,598
      CC2 = 0,598
      Yes I have 20V on the PPVBUS_USBC but only when I have 2 usbc cable connect on MacBook and only on the last cable connect the other was on 5V
      • GRrHaG
        • Oct 2023
        • 7
        • France
        on PP3V3_S2, in diode mode i have 0.04 and 30Ohm in RES mode on LC710, with P3V3S2_PWR_EN = 0V and PP3V3_S2 = 0V
        I view on boardview PP3V3_S2 must have 0.42 in diode mode
        This is a short ? or normal ?
        • mon2
          • 14698
          It is a short. Review the link shared by this tech on the Rossmann forum - your case appears to be the same.
          https://www.badcaps.net/forum/troubl...revive-restore
          • GRrHaG
            • Oct 2023
            • 7
            • France
            UC710 was short on several pin, I whent to change it.
            but what is his reference , UC710 SN621371 . I find his reference on aliexpress only
            how I can find the manufacturer and manufacturer part number ?
            • mon2
              • 14698
              Texas Instruments. Part datasheet is not available to the public.
              SN621371RGXR
              • GRrHaG
                • Oct 2023
                • 7
                • France
                thanks
                • todordm
                  Macbook A2338 / A2337 - Replace SSD
                  by todordm
                  There are a lot of Video Tutorials how the SSD of A2338 or A2337 can be upgraded. Normally they say you can order the bigger SSD chips (0 and 1) from China. But as far as I understand you can take the SSD chips of one A2337/A2338 and install on another, put to DFU mode, do the recovery, reinstall etc... I tried that several times (tried to upgrade 256GB to 512Gb, then to 1TB, then to another 256Gb)... nothing worked. So my question to the community is: can I just take the SSD chips from one A2338 and intall them on another A2338 (taking care of course of the 0 and 1 positions)? Or I have always...
                  01-17-2024, 03:55 AM
                • User555111
                  A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
                  by User555111
                  Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
                  02-05-2024, 08:16 AM
                • jkruns
                  Macbook Pro M1 A2338 - how to test for 20V?
                  by jkruns
                  I have a stack of liquid damaged A2338's, most of which don't draw more than 5v and thus won't turn on.
                  So far I've put back the main boards back after cleaning and repair attempts and connected every single component before testing. This obviously take a huge amount of time.
                  My question is (maybe not limited to A2338 boards): what's the bare minimum that needs to be connected in order to test if it will draw 20V? Should it draw 20V without the battery connected?
                  10-18-2024, 10:38 AM
                • jkruns
                  M1 A2338 screen and touchbar issues after cleaning up liquid damage
                  by jkruns
                  This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                  My patient is an A2338 Macbook Pro M1 (late 2020).
                  It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                  04-22-2024, 06:45 AM
                • classicandy
                  MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
                  by classicandy
                  Hi Everyone,
                  Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
                  UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
                  04-14-2024, 12:00 PM
