Macbook Pro M1 A2338 - how to test for 20V?
  • jkruns
    • Mar 2024
    • 40
    • Netherlands
    I have a stack of liquid damaged A2338's, most of which don't draw more than 5v and thus won't turn on.
    So far I've put back the main boards back after cleaning and repair attempts and connected every single component before testing. This obviously take a huge amount of time.
    My question is (maybe not limited to A2338 boards): what's the bare minimum that needs to be connected in order to test if it will draw 20V? Should it draw 20V without the battery connected?
  • tomtom67
    • Mar 2021
    • 16
    I always test for 20V with the bare board, so nothing needs to be connected but the USB adapter. Some models need battery and/or trackpad connected to fully boot though.
    In FlexBV / OpenBoardData there is one solution/checklist available to ease in 20V startup debugging.
    Just had a Coke bathed A2337 here that put up a fight; turned out there were two tracks disconnected and a bad resistor in the ISL area, plus both double-mosfets (Q5230, Q5240) were blown.
    • jkruns
      • Mar 2024
      • 40
      • Netherlands
      Thank you for that!
      With regards to FlexBV, would you say it's worth the investment just for the solution/checklist?
      • tomtom67
        • Mar 2021
        • 16
        As gar as i know even the free version has openboarddata integrated, so you may be fine with it. But as sattes on his web site, the first two jobs will pay the license fee, plus i wanted to support PLDs work. I mean it’s not much money compare to other tools, and well worth it.
        • reformatt
          • Feb 2020
          • 1832
          The butterfly mode (where it shows both sides of the board simultaneously and the connection lines between nets between the two) is a real time saver. The integration between selecting a component on the boardview and auto selecting it (or at least searching each instance) in the schematic is huge.
          If you are doing frequent board repairs, it pays for itself just in the time you save. The Openboard data is a bonus. Paul has done amazing work on this and should be rewarded for it.
          • vladimir1909
            LlamaTester Alpha V0.1 Macbook Quick test
            by vladimir1909
            I would like to share a small MacBook diagnostic application that I've been developing. The goal of this tool is to provide technicians and repair enthusiasts with a simple way to test and gather information about a MacBook. Current features
            • Display test
            • Keyboard test
            • Camera test
            • Audio test
            • System overview with relevant hardware information
            • Charger and power adapter information
            The application currently works on macOS Monterey and newer versions.
            Please note that this is still an alpha release, so you may encounter bugs or incomplete...
            07-09-2026, 12:07 PM
          • Spillet45
            MacBook Pro Retina 15-inch (A1398) (820-00163A) Does not power on, thinks a battery is connected.
            by Spillet45
            Hello everyone! I'm trying to diagnose a fault. I don't have much experience, so I would appreciate any help.
            Symptoms:
            It stopped charging, drained the battery completely, and shut down. When powered from the adapter, it shows the battery symbol with a lightning bolt and then turns off. Without the adapter — completely dead. The charging indicator does not light up. Once I managed to start it using shift+opt+cmd+power for 5 seconds, then only power for 5 seconds, and then a short press on power. (I assume this was some kind of SMC bypass, found it somewhere on the internet)....
            05-29-2026, 01:39 AM
          • yair27
            Built a MacBook Board-Level Repair Assistant — Looking for Experienced Techs to Test It
            by yair27
            Note by admin: this software is not endorsed, affiliated, or guaranteed by Badcaps. Please use caution when installing or using software provided by third parties as we can not be responsible for an undesired outcome.
            First of all, sorry if this is not the right place to post this — please feel free to remove it if it doesn’t fit the forum rules.
            I’m working on an Alpha version of a MacBook board-level repair system that brings several things into one place: schematics, boardview, search, repair cases, and AI-assisted diagnostic guidance....
            05-23-2026, 05:39 AM
          • silver60618
            Macbook A2338 - Ripped off Trackpad Posts - No Keyboard/Trackpad function
            by silver60618
            Hi gang, I was hoping someone could help me. Im working on a A2338 Macbook, with torn off standoff posts for the connectors shield. The laptop works, but gets no trackpad/keyboard/haptic functions.
            It looks like it just sits on a ground plane. The PPBUS_AON Pins are recieving 12v, pp3v3 present. I dont see any traces going to these pads or near vicinity.
            Any ideas what I can check? Any help would be appreciated....
            03-16-2026, 05:46 PM
          • Orux
            Macbook Pro M1 A2338 13"
            by Orux
            I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
            I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
            One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
            09-22-2025, 12:54 PM
