A1706 820-00239 No power 20v 0.150A
  • tommy97
    • Mar 2023
    • 167
    Hi, i'm having problem with board from MacBook a1706, at the beginning it had problem with short on U7100 20v 2.1Amp instant - fixed. Then was a problem with one of CD3215, And short on 3.3 LDO, resolved. Now machine does not start up 20v 0.150amp PMC was getting hot so i removed it no change, then i found problem...
    PP1V0_SUS SHORT
    PP1V0_SUSSW SHORT
    When apply 0.8v it consumes 8AMP, not visible shorts, any cap when I apply voltage gets hot thermal camera only detect that.
    Any ideas?
    (Question in the other hand if i'd be about to swap NANDs what have to be replaced with them also?)
  • mon2
    • 14662
    Check the resistance to ground of these rails. Sounds like a dead cpu. Remove the heat sink to check if the cpu is heating up.
    • tommy97
      • Mar 2023
      • 167
      PPV1V_PCH_REG_R - 0 Ohm
      PP1V0_SUS 0 Ohm
      PP1V0_SUSSW 0 Ohm​
      • tommy97
        • Mar 2023
        • 167
        Any ideas? mon2
        • mon2
          • 14662
          Could not locate the first posted net name but did find a P1V0PCH_REG_R. It is important to use the exact net name as found in the schematic for a quick search. This power rail powers the PCH which is part of the CPU. With a zero resistance, this usually means the PCH / CPU is dead. Do wait on other comments but that appears to be the situation here.
          You can confirm the same with using DIODE mode on your meter. Red meter probe to ground; black meter probe on the same PPVCCPRIMCORE_SUS_PCH rail to measure. What is the measurement?
          Respectively, if you remove the heatsink off the CPU and perform an injection 0v8 on these 0 ohm rails, guessing that the CPU will be heating up due to this short event.
          • iMuhtaseb
            A1706 - 5v due short 3.3v LDO
            by iMuhtaseb
            Board was OK but after keyboard replacement; we found short on 3.3 LDO on UB300 (CD3215).. I removed it and of course I tore off some pads because its undefiled.. pads are repaired successfully.. diode and continuity tests done Pads were USB_UPC_TA_F_P and TP_UPC_TA_SWD_DATA and UPC_TA_SPI_MISO..
            After replacing UB300 the watts consumption lowered since short is gone but still is stuck @ 5v (0.06amps)
            I noticed few balls around UB400 so I assumed it needed reball; reballed and replaced it; still 5v.. on both sides
            While on the other wing U3200 and U3100...
            11-18-2024, 07:01 AM
          • rilley
            MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
            by rilley
            I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
            I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
            My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
            And the resistor L4004 is literally burned.
            From what I see from the schematics, it does not affect any other rails, only the connection to the display...
            07-10-2024, 01:57 AM
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • madjid911
            A1706 short PP3V3_S5
            by madjid911
            Hi friends,
            I have a macbook pro A1706 820-00923-A that won't start no signs of life, no liquid, checking the voltages I found PP3V3_S5 was shorted, I removed all the processor coils, but when I 'injects a voltage it is the processor which reacts, can you confirm to me that this is definitely coming from there please?
            I have 20V on the usb-c connector, and 13v stable on​ ppbus_g3h.
            I saw that a track had burned out on PPVIN_2V7NAND_LB after resistor R9350
            I injected voltage on L7660 pin 1 in short but only the processor reacts
            Thanks for your...
            05-18-2024, 12:33 PM
          • Stephen
            MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
            by Stephen
            I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
            02-06-2025, 12:03 PM
