Lenovo Z50-70 NM-A273 BIOS SPI not supported
  • lord
    • May 2011
    • 319
    • Croatia
    Hi guys,
    Anybody came accross this one?
    I put in a new BIOS file, old one was corrupted (don't have the original)
    Tried first with Z50-70 bios but i couldn't update to latest BIOS via upgrade utility, the tried for Z40-70, i manage to upgrade to latest but this warning message is always there (except for the first boot)
    Anybody have any ideas?
Name:	WhatsApp Image 2024-01-25 at 10.20.04.jpg
  • mon2
    • Dec 2019
    • 14832
    Did you use the original bios from the motherboard or purchased an equivalent? Not sure but sounds to me like the motherboard is extracting the embedded IDs from the flash device and comparing the values to a look up table (database) of supported flash chips. Respectively, this message is a flag that the IDS from the installed flash device do not match the supported list of devices.
    • lord
      • May 2011
      • 319
      • Croatia
      First I used an equivalent but then changed back to original
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Open your bios with UEFITool -> click the Desriptor region -> flash ROM ID's are shown at "Flash chips in VSCC table:"
        For example:
        EF6017h
        EF4018h
        C22018h
        EF6018h
        C84017h
        • EF6017h = Winbond W25Q64FW - 1.8V
        • EF4018h = Winbond W25Q128FV / W25Q128BV
        • C22018h = Macronix MX25L12805/12835/12845
        • EF6018h = Winbond W25Q128 - 1.8v
        • C84017h = GigaDevice GD25Q64 / GD25Q64B
        Become a Badcaps supporter
        Thanks to all supporters.​
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Its seems like a bios issue. Why not download bios update from lenovo website by putting your serial number and then extracting the bios. Then flash it with an spi programmer. If you dont know how to do this,post a request in bios subforum. Bios for Z40-70 and Z50-70 may be slightly different.
          • lord
            • May 2011
            • 319
            • Croatia
            For example:
            EF6017h
            EF4018h
            C22018h
            EF6018h
            C84017h
            I sadly don't have the original BIOS, here is the extracted information from BIOS i downloaded from web
            EF4017 (Winbond W25Q64)
            C84017 (GigaDevice GD25x64)
            C22017 (Macronix MX25L64)
            1C7017 (EON EN25QH64)
            The chip that is on the board is N25Q064AX3E
            • lord
              • May 2011
              • 319
              • Croatia
              i tried that, same thing, this is the BIOS from Lenovo website
              • lucaszmn
                by lucaszmn
                Problem:
                Initial Findings:
                • I concluded that the
                08-12-2025, 03:01 PM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • grimacelord
                Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                by grimacelord
                Hello there.
                I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                History:
                1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                I searched for this error online and discovered...
                03-15-2023, 03:29 PM
              • to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                by to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                I have opened the laptop and identified the main BIOS chip...
                10-24-2025, 01:35 AM
              • mkdj
                Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                by mkdj
                Dear all,
                I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                Here the steps I have taken to fix the laptop:
                - downloaded latest BIOS from Lenovo Website...
                10-18-2025, 03:43 AM
