macbook pro a1989 power on but black screen
  • reset1986
    • Dec 2014
    • 308
    • italia
    hi everyone, i have this macbook pro with 820-00850a motherboard,
    at the beginning it had burn marks on the flat connector on the display side, replaced the flat and connector on the display side but the problem remains,
    when I turn on I hear the boing, the keyboard lights up but there is no display activity, even in backlight there is no image,
    checked fuse, there are no short circuits,
    suggestions?
    I don't own spare display
    from the measurements are missing
    PPVIN_S0SW_LCDBKLT 0 V
    CPUGT_SW1 0V
    PVCCEDRAM 0V
    thanks
  • mon2
    • 14677
    Re: macbook pro a1989 power on but black screen
    1) Try a PRAM reset
    2) Post the voltage readings for:
    PP5V_S0SW_LCD
    PPVOUT_S0_LCDBKLT
    PPVIN_S0SW_LCDBKLT
    LCDBKLT_EN_L
    PPVIN_S0SW_LCDBKLT_F
    BKLT_EN_R
    EDP_BKLT_EN
    I2C_TCON_SDA
    I2C_TCON_SCL
    • reset1986
      • Dec 2014
      • 308
      • italia
      Originally posted by mon2
      1) Try a PRAM reset
      PP5V_S0SW_LCD
      PPVOUT_S0_LCDBKLT
      PPVIN_S0SW_LCDBKLT
      LCDBKLT_EN_L
      BKLT_EN_R
      EDP_BKLT_EN
      I2C_TCON_SDA
      I2C_TCON_SCL
      ok,mesure
      PP5V_S0SW_LCD 5 V
      PPVOUT_S0_LCDBKLT 0 V
      PPVIN_S0SW_LCDBKLT 0V
      LCDBKLT_EN_L 12.5 V
      PPVIN_S0SW_LCDBKLT_F 12.5 V
      BKLT_EN_R 0V
      EDP_BKLT_EN 0V
      I2C_TCON_SDA 3.3V
      I2C_TCON_SCL 3.3 V
      all measurements were made with the display disconnected with the power cable only
      replaced q8400, always no display signal
      thanks
      • reset1986
        • Dec 2014
        • 308
        • italia
        PPVIN_S0SW_LCDBKLT must it always be 12.5v even with the panel disconnected?
        • piernov
          • Jan 2016
          • 4439
          • France
          Diode mode to ground EDP_INT_AUX_N EDP_INT_AUX_P
          • reset1986
            • Dec 2014
            • 308
            • italia
            sorry for the delay, I had put this mac aside, today I try the values of the 2 signals and let you know, thanks:pensiero:
            • reset1986
              • Dec 2014
              • 308
              • italia
              EDP_INT_AUX_N in short,
              EDP_INT_AUX_P correct value,
              measured in diode mode,
              EDP_INT_AUX_N is generated by the cpu,
              cpu broken?
              • reformatt
                • Feb 2020
                • 1510
                Louis has covered this design issue a few times. Pin 43 (PPVOUT_S0_LCDBKLT) and Pin 1 (EDP_INT_AUX_N) are side by side on J8500. Any liquid damage to this connector can potentially allow that high voltage into that data line and damaging the CPU. Crazy design.
                • Strolch
                  • Nov 2017
                  • 245
                  • Deutschland
                  Louis addressed this design issue a couple of times. Pin 43 (PPVOUT_S0_LCDBKLT) and pin 1 (EDP_INT_AUX_N) are next to each other on J8500. Any liquid damage to this connector could potentially allow this high voltage to enter this data line and damage the CPU. Doesn't the A1989 have a chip like the U9850 that can be swapped out, like the A1707? Is the CPU definitely affected in this case? On my board, pin 43 and pin 1 also had a short circuit!
                  • HTR-Informatique
                    Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                    by HTR-Informatique
                    YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                    I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                    On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                    I also changed the screen because the PC fell and the screen was broken.
                    I changed the battery with a new and original battery.
                    I also had corrosion/oxidation on the...
                    02-09-2025, 06:51 AM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • VcemPzd
                    Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                    by VcemPzd
                    Hello everyone !
                    My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                    04-28-2025, 10:14 AM
                  • DaniK
                    Acer Aspire E5-574-52RH - black screen
                    by DaniK
                    I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                    Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                    Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                    Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                    The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                    Symptoms are:
                    - random black screen after displaying Acer logo...
                    02-21-2024, 06:27 AM
