DA00P2MB6D0 REV D Missing 3v5v LDO
  • Tend0
    E.E.C.S
    • Oct 2021
    • 92
    • Burkina Faso
    Hello everyone! Happy New year to all, cheers to new beginings and exciting adventures ahead!
    I have a issue with this motherboard all voltage on charger ic are good and 3v5v ic's are suplied but not activate to deliver 3and 5v
    i need our help to find a solution
    i joint below shematic, brd and 3v5v datasheet
    [Mod. Edit]
    Schematic and boardview -> https://www.badcaps.net/forum/troubl...01#post1418201
    Reminder: rules and organization of this section
    https://www.badcaps.net/forum/showthread.php?t=117483​
    Last edited by Vesko356; 01-06-2024, 11:49 AM. Reason: Attached schematic and boardview removed and replaced with link
  • mon2
    • Dec 2019
    • 14261
    Have not reviewed the schematics because need to fix our car’s fog lights. Remove all power and check the resistance to ground of these missing rails. Post the measurements. If they are not low, check the voltage to ground of the enable pins for each.
    • Tend0
      E.E.C.S
      • Oct 2021
      • 92
      • Burkina Faso
      Thanks for reply
      resistance to ground on pc43 (+3VS5) = 15,5 K
      resistance to ground on pc43 (+5VS5) = 64 k
      +3VPCU= 33k
      +5VPCU=175k
      Voltage to ground enable pin;
      PIN 11 EN2 (PU10) = 0V
      PIN 11 EN2 (PU11) = 0V
      Multimeter UNI-T UT890C
      • mon2
        • Dec 2019
        • 14261
        Ok. Enables are not correct to enable the LDO rails. The enables function with a resistor based voltage divider. They accept a high voltage (adapter raw voltage of ~19v) and lower it to a safe value for the ENable pins.
        Each works with the +VIN pin. Carefully measure the voltage to ground of the +VIN power rail which is the voltage after the DCin mosfets.
        If +VIN is not ~19v, proceed to measure the voltage to ground readings on the charger IC:
        ACDRV (pin #4)
        ACPRES (pin #5)
        REGN (pin # 16)
        Click image for larger version  Name:	enable_ldo.png Views:	0 Size:	132.8 KB ID:	3174137
        • Tend0
          E.E.C.S
          • Oct 2021
          • 92
          • Burkina Faso
          voltage after the DCin mosfets ( PR57 ) 19.56V
          ACDRV (pin #4) 25.03V
          ACPRES (pin #5) 3 V
          REGN (pin # 16) 6V
          • mon2
            • Dec 2019
            • 14261
            Then either pr57 is defective or the trace to this enable pin is broken. Remove all power. Meter in resistance mode.
            measure the resistance on each side of pr57. Next measure the resistance from the left side of pr57 that is confirmed to have the ~19v and to the enable pin on the regulator.
            update: another possibility is that the enable pin is being pulled or shorted to ground. Measure the resistance to ground of this enable pin with no power.
            post all measurements.
            • Tend0
              E.E.C.S
              • Oct 2021
              • 92
              • Burkina Faso
              Measurement on PIN 1 of PR57 is not constant with a caliber of 600 Mohm it start at 4.12Mohm and decreases
              on PIN 2 of PR57 is constant = 143 kohm.
              resistance from the left side of pr57 to the enable pin on the regulator is not also constant with caliber set to 600K start 121k andincrease
              enable PIN 11 to ground is 102K
              • mon2
                • Dec 2019
                • 14261
                Pr57 appears to be defective. Apply flux with low air pressure and use tweezers to carefully remove this part. Do not lose the resistor.
                measure the resistor when it is cooled off and on your work table. It should be ~499k ohms and stable. If not the part should be replaced.
                check the enable pin of the other power rail in the same way.
                the parts are inexpensive so order spares and recommend to also order the other resistor (pr59) on the enable pin. Post each measurement.
                • Tend0
                  E.E.C.S
                  • Oct 2021
                  • 92
                  • Burkina Faso
                  OK I will do it tomorrow thanks
                  • Tend0
                    E.E.C.S
                    • Oct 2021
                    • 92
                    • Burkina Faso
                    pr57 = OL on 600k calibre
                    pr3264 = OL
                    so what can be cause these resistor defected it's my first time to face thes issue on laptop motherboard, verry glade to learn more.
                    i don't know resistor part size to order it's verry smal. how can find size?
                    there is way to force enable pin with wire jumping?
                    thanks for our support
                    • mon2
                      • Dec 2019
                      • 14261
                      https://www.digikey.ca/en/resources/...oltage-divider
                      with 499k and 150k + 19v as in the input voltage; the EN pin was to receive ~4v4 to enable. Be sure to study this area for possible corrosion / liquid damage. Share clear pictures of these 2 parts for this regulator and also the other that is not working. We must be sure that the proper pin (EN) is being reviewed.
                      If indeed these 2 parts are defective, you can consider to apply a piece of wire from this EN pin or resistor pad onto the REGN pin of the charger IC. That is, when the charger IC is being powered, the REGN pin will be 6v and this 6V can then be used to enable this regulator. The same 6v should be fine to enable the other regulator. This is only a suggestion but the best one is to replace these parts. If you do this, the 499k resistor should be removed off the logic board for each regulator.
                      It is strange that BOTH resistors on the 2 different regulators are damaged. Do post clear pics of all these resistors before proceeding. The parts are most likely 0402 or 0603 in SMD size and each are inexpensive to source. The REGN bypass trick should work fine as long as the regulator EN pins are not being shorted which they do not appear to be based on your past resistance to ground checks. Be sure to use a very fine piece of wire that is insulated and low enough heat to melt the solder - too much heat will destroy the PCB pad. Too low of a wire gauge will tear the SMD pad off the logic board = each will be a messier repair job to fix.
                      Click image for larger version  Name:	resistor_calculator.png Views:	0 Size:	41.9 KB ID:	3174809
                      • Tend0
                        E.E.C.S
                        • Oct 2021
                        • 92
                        • Burkina Faso
                        all test with enable pin to each +vin resistor pin are good
                        • mon2
                          • Dec 2019
                          • 14261
                          What is the voltage to ground on PU11 (pin #11 = EN2) ? Next, remove all power and measure the resistance across the resistor @ PR3264. What is the measurement? From the BV files, these are the proper locations for these resistors and matches your last post.
                          • dqtech
                            asus a450c 3v5v missing
                            by dqtech
                            asus laptop a450c missing 3v 5v
                            can anyone guide me how to read this...step 1. PJP8100 got 19v...
                            2. PSL8801 no have voltage
                            this is schematic and boardview for reference
                            [Mod. Edit-Vesko356]
                            Read the rules please, do NOT attach schematic, boardview etc. in this section!
                            Schematic and repair guide ---> https://www.badcaps.net/forum/showth...18#post1252318
                            07-05-2023, 07:27 PM
                          • ugamazing
                            820-02020 PPBUS_AON missing
                            by ugamazing
                            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                            02-05-2025, 04:21 PM
                          • jpreza
                            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                            by jpreza
                            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                            Looking at the card, it appears to be missing the following:
                            1x 1.0uH inductor - orange square
                            2x...
                            11-01-2024, 10:54 PM
                          • gurj1979
                            Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                            by gurj1979
                            Hey guys.
                            Need help with this one.
                            Fan not spinning due to missing PWN Fan signal.
                            Also 5 seconds from powering up it freezes, unless in BIOS.
                            But as soon as Windows starts to load, it will freeze.
                            CPU is COLD / Room temp when it freezes.
                            I've replaced the CPU, same problem.
                            Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                            Replaced fan - same problem.
                            Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                            Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                            08-19-2024, 05:22 PM
                          • salopian
                            Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                            by salopian
                            Hello. I would need some advice please.
                            My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                            He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                            I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                            I have already replaced the logic board with another...
                            02-27-2021, 07:30 AM
