Macbook pro A1278 doesn't turn ON 820-3115-B
  • Adogabriel100
    knowledge seeke
    • Aug 2021
    • 36
    • peru
    Hi! this is a Macbook pro A1278 MB: 820-3115-B. It came to me from another store with an attend to repair. Now im trying myself to repair this one.
    It doesn't turn on and there is no green/orange light either.
    Im using mac power cable by-3200.
    those are the actual voltajes values and missing lines:
    im stuck here with this one here. dont know where to look now. im thinking about SMC (i already change it, dont know if it is ok)
    thanks for the help!
    PPBUS_G3H = 12.26V
    PPBUS_S5_HS_OTHER_ISNS = 12.26V
    PP3V42_G3H = 3.47V
    PPVRTC_G3H = 3.47v
    SMC_BC_ACOK = 3.33V
    PP1V2_S5_SMC_VDDC = 1.2V
    SMC_ONOFF_L = 3.47V
    SMC_RESET_L = 3.44V
    SMC_BATLOW_L = 0V
    SMC_ADAPTER_EN = 0V
    PP3V3_S5 = 0V
    PM_SYSRST_L = 0v
    PM_RSMRST_L = 0V
    PM_PCH_PWROK = 0V
    M_RSMRST_L = 0V
    PM_PWRBTN_L = 0V
    SMC_PM_G2_EN = 0V
    PD: i don't have oscilloscope to check the CLK32k.
  • mon2
    • 14687
    SMC_BATLOW_L = 0V
    Power adapter is under rated to power this unit if LOW = 0 volts. Which one are you using?
    • Adogabriel100
      knowledge seeke
      • Aug 2021
      • 36
      • peru
      Hey mon2! Im using mac power cable by-3200.
      • mon2
        • 14687
        PPBUS_G3H = 12.26V
        SMC fault.
        reference:
        820 2936-B no green light, PPBUS_G3H 12.29v | Rossmanngroup Forums
        PM_PWRBTN_L = 0V
        Is your power button stuck? Check this line.
        • Adogabriel100
          knowledge seeke
          • Aug 2021
          • 36
          • peru
          Of course i thought the same thing, i replace the SMC and it still show the same behavior.
          in that post that you re put in as reference. The guy says that he replace the SMC twice and after that the mac has the same behavior. in fact, he take off the SMC and put on another MB and it work normally.
          I'm going to look for another SMC and try it again. I'll change it and then I'll tell you how it went.
          • mon2
            • 14687
            Do check if the power button line is switching between LOW and HIGH logic levels when you press and release.
            • Adogabriel100
              knowledge seeke
              • Aug 2021
              • 36
              • peru
              yes, it does the switch between LOW and HIGH logic levels.
              I changed the SMC again and it does the same behavior.
              • reformatt
                • Feb 2020
                • 1528
                First, there is a typo in the schematic for the SMC. Main power line is PP3V42_G3H, not PP3V3_S5_SMC (which is derived from the PP3V3_S5 supply, controlled by the SMC, so you have a chicken and the egg situation).
                With non functional SMC's, you check
                1. 3.42V at L4901
                2. PP3V3_S5_AVREF_SMC present
                3. PP1V2_S5_SMC_VDDC present
                4. SMC_RESET_L = 3.3V
                5. XTAL cct (Y5010, R5010 etc) is not corroded or tracks missing to SMC.
                If the SMC is working, you should at least have SMC_PM_G2_EN go high to enable PP3V3_S5.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  Not a typo, PP3V3_S5_SMC is aliased to PP3V42_G3H_REG. It's a confusing name nonetheless.
                  Missing, bad or corroded resistors around SMC can also cause issues, such as the SMC JTAG pull-up resistors or SMC_WAKE_L. And as usual the J5100 debug connector, although it's not common to get corrosion there on MBP, unlike MBA.
                  • reformatt
                    • Feb 2020
                    • 1528
                    Adobe search had me landing on PP3V3_S5_REG as the alias, but was in fact PP3V3_S5_SMCBATLOW, should look closer (I was doing this to fill in time while I was waiting on creating a Windows 11 installer). Anyways, I know you don't like Adobe.....
                    • Adogabriel100
                      knowledge seeke
                      • Aug 2021
                      • 36
                      • peru
                      Thank you guys reformatt, piernov and mon2 for the help. in fact, the track of the Resistor R5010 (SMC_XTAL) to SMC was missing​. Jump wired and for now, everything is working normal. Thanks again!
                      • dreamflowers09
                        • Feb 2012
                        • 31
                        great
                        • Adogabriel100
                          Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                          by Adogabriel100
                          Hey! This is a A1278 macbook 2011.
                          Problem: Not turning on / No green light
                          Im using by3200s charger.
                          Voltajes:
                          PPBUS_G3H = 12.26v
                          SMC_RESET_L = 3.3v
                          PP3V42_G3H = 3.42v
                          U7000 =
                          Pin 1 CHGR_AGATE = 0v
                          Pin 2 CHRG_DCIN = 19v
                          Pin 3 CHRG_ACIN = 4.6v
                          Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                          Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                          Pin 12 PP3V42_G3H = 3.42v
                          Pin 13 CHRG_RST_L = 3.3V
                          Pin 14 SMC_BC_ACOK = 0.8V
                          Pin 19 PP5V1_CHRG_VDD = 5.05V
                          Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                          04-01-2024, 01:02 PM
                        • Rezendes
                          Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                          by Rezendes
                          Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                          I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                          The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                          05-10-2024, 02:18 PM
                        • pcbmaniac
                          MacBook A1278 (3115) No PPBUS_G3H Issue
                          by pcbmaniac
                          Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                          I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                          1. U7000 Measurements:
                            • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                          2. Resistors:
                            • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                          Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                          • If I also decide to replace the SMC, do I need to order it pre-programmed,
                          12-02-2024, 04:12 PM
                        • sizar00740
                          macbook pro 13 inch a1278 820-2879
                          by sizar00740
                          please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
                          07-30-2025, 10:21 AM
                        • envym
                          by envym
                          Hi everyone!
                          06-27-2025, 08:54 AM
