Looking to learn about troubleshooting my Lenovo L14 Gen 1
  • Lifeisfun
    • Apr 2025
    • 47
    I did check for shorts on the regulator chips and did not find any so I soldered it back ( also ordered replacements but my experience with ICs from China is bad)
    Will test it and see if it works, I didn't want to cause damage with the EC chip removed.
    The info about editing the laptop details I got from the pre-programmed chip seller on eBay (very reputable item # 297257916579)
    After fitting this chip you will need to fill in the missing data from the bios setup
    like the Serial Number, Board Number, This is done using a usb drive at bootup
    you need to download (Lenovo Maintenance Diskette) See picture No2.
    The Type and Serial Number can be found on the sticker on the back cover on your laptop.
    I'll see how it goes.
    Thanks again!​
    • m1ch43lzm
      • Mar 2019
      • 921
      • Peru
      I suggest sending a message to the seller to confirm if you need to add that info after replacing EC, as i don't know the specific details about your motherboard, as most laptops store that info on the BIOS
      If needed, they may be able to add that info while programming the EC
      Laptop should power on after replacing EC in any case
      • Lifeisfun
        • Apr 2025
        • 47
        Will do!
        Thank you!
        the 3.3V regulator is working fine
        • Lifeisfun
          • Apr 2025
          • 47
          To my absolute surprise it's partially alive! 😅
          It will make funny tone melody when powered on, charge the battery but nothing else.
          I do not have DDR4 stick handy, is this the reason why it wouldn't boot or show anything on the display?
          Thanks!
          • Sephir0th
            • Oct 2020
            • 1289
            Without a EC the board can not boot up. This is impossible. You need to wait until you can replace it.
            FairRepair on YouTube
            • Lifeisfun
              • Apr 2025
              • 47
              Yes, that was already done, it wouldn't charge or respond to the power button either.
              • m1ch43lzm
                • Mar 2019
                • 921
                • Peru
                #27
                Thanks!
                It won't work without RAM, as that board doesn't have onboard memory
                Schematics and board view only show 1 RAM slot and no onboard RAM, please install memory (that may be the meaning of the "funny tone" you heard)
                • Lifeisfun
                  • Apr 2025
                  • 47
                  Will do! Thanks for the confirmation, you are great help!
                  • Sephir0th
                    • Oct 2020
                    • 1289
                    Oh, you are right. Missed that it was already done.
                    Well, then it could be still a underlying problem, which more or less means that we have to start over with the diagnostics to fins the next problem. I would begin with a close look at pictures of how the EC was soldered...
                    Of course only when inserting the RAM doesn't change anything
                    • Lifeisfun
                      • Apr 2025
                      • 47
                      Got the DDR4 memory but sadly still no picture, it will consume 40mA before I press the power button, then it will settle on 500mA, CPU is warm and if I leave it on for long time the fan will kick in.
                      If I hold the power button it will reboot after 10 s or so, if I do that two times in the row it will turn off and not reboot.
                      What I noticed is I get no VCCGFXCORE_I voltage on the PL1003 coil, is this normal?
                      Any ideas welcomed.
                      • m1ch43lzm
                        • Mar 2019
                        • 921
                        • Peru
                        #31
                        https://www.badcaps.net/forum/troubl...rpose-of-vccgt
                        From post #2
                        I am missing VCCAXG/VCCGFX/VCCGT (iGPU core voltage), how do I solve it?
                        The iGPU core voltage is almost never relevant. It typically only comes up when there's a significant load on the iGPU. It can often be seen spiking a couple of times on the oscilloscope when POSTing.
                        In other words, it's generally normal that it's missing. If you have some kind of issue with the machine, the cause is most likely elsewhere.
                        Does the laptop react to caps lock key? Same with a basic, cheap USB wired mouse, it should light up the sensor (don't use a gaming mouse with RGB lights, it will mislead you)
                        If the caps lock LED turns on/off as you press it, then the issue is "No display"
                        Otherwise, is "No POST/no boot"
                        Do you still get the beep codes? If yes, you can check with "Lenovo PC Diagnostics" app for your phone
                        You can also build this simple USB port tester, the red LED blinks if there's activity (system is alive)
                        Click image for larger version  Name:	probador-puertos-usb-R-FZDA6s.jpg Views:	0 Size:	11.4 KB ID:	3634346
                        The resistors are 100 ohms (i saw several versions of the same circuit, with resistors from 100 ohms to 1k, whatever works), the red LED is connected to D+ through a 100 ohm resistor
                        Also wait for Sephir0th reply
                        • Lifeisfun
                          • Apr 2025
                          • 47
                          From post #2
                          Very interesting, I thought that could be my problem.
                          No longer get any beeps out of it even with the memory removed again (this is the memory I got DDR4 16GB 3200MHz (PC4-25600) CL22 SODIMM)
                          No light or response from the caps lock key
                          Yes USB mouse will light up and blink couple times when booting, after that the LED is steady on.
                          Not sure where to look further
                          No change when I plug in the battery only difference is that the battery charging circuit coil gets hot and the input power consumption is close to 3A.
                          Thanks again for your time!
                          • Lifeisfun
                            • Apr 2025
                            • 47
                            I know it doesn't look pretty but I checked every single pin and they are all soldered.
                            Click image for larger version  Name:	PXL_20250511_081336244.jpg Views:	0 Size:	3.93 MB ID:	3634471 Click image for larger version  Name:	PXL_20250511_081841191.jpg Views:	0 Size:	3.56 MB ID:	3634472 Click image for larger version  Name:	PXL_20250511_081857938.jpg Views:	0 Size:	3.69 MB ID:	3634473
                            • Lifeisfun
                              • Apr 2025
                              • 47
                              Here is link to video of the power meter when it powers up
                              https://photos.app.goo.gl/uN8PJgtKXa3UPpKE8
                              • Lifeisfun
                                • Apr 2025
                                • 47
                                Just some additional info on what I tested so far:
                                I did check the EC chip soldering pin by pin and they are all connected
                                I checked all coils and looks like all voltages are present except the VCCGFXCORE_I voltage I asked above.
                                Since there is no response from the keyboard I checked for power on the connector and there is 3.3V present.
                                When I power it on (without battery and cmos batt connected)
                                The power button (on its own) blinks 2 times then it turns on, fan turns on for couple seconds and turns off again.
                                It takes 20V and power meter shows after while about 450mA
                                It will sit like this long time without any change (nothing is hot, only some components warm to touch like the CPU and some coils)
                                If I press the power button nothing happens
                                IHold it it will blink twice again and reboot to the same state. (no change from above)
                                When I attempt to reboot it for the 2nd time holding the power button it will turn OFF and the power meter shows consumption about 42mA
                                After this the power button no longer responds. (also tried keyboard but nothing)
                                To reboot again I have to unplug the USB-C and plug it in again.
                                Mouse connected to USB port blinks couple times and after the amperage settles down it stays lit.
                                Any ideas would be welcomed!
                                Thank you!
                                Sephir0th
                                m1ch43lzm
                                • m1ch43lzm
                                  • Mar 2019
                                  • 921
                                  • Peru
                                  #36
                                  Get the ThinkPad E14, R14, E15, S3 Gen 2 Hardware Maintenance Manual (HMM) from here:
                                  https://support.lenovo.com/us/en/sol...-e15-20rd-20re
                                  From page 46
                                  LCD Self Test
                                  When you turn on the computer and the LCD goes black, run LCD Self Test to help you determine whether the LCD functions normally.
                                  To run LCD Self Test:
                                  1. Ensure that the computer is connected to ac power. Then, press the power button for about seven seconds to turn off the computer.
                                  2. Press Fn, left Ctrl, and the power button at the same time. If the computer displays five solid colors in sequence across the entire screen, it indicates that the LCD functions normally.
                                  3. The test lasts for about 20 seconds and then exits automatically. You also can press the power button to exit the test.
                                  If you get beep codes (speakers plugged in of course), check page 44, download the Lenovo PC diagnostics app on your phone (link in hardware maintenance manual is broken, search app store/play store) to decode beep codes
                                  • Lifeisfun
                                    • Apr 2025
                                    • 47
                                    From page 46
                                    Thank you, will do that.
                                    Unfortunately it no longer makes any sounds. It did only the first time I powered on without memory, but now even when the stick is removed no beeps.
                                    • Lifeisfun
                                      • Apr 2025
                                      • 47
                                      Another question, any reason for the BQ chip to be 49C when the battery is not even connected? The mosfets around tested OK and not shorted.
                                      When I connect the battery (12.6V charged to 11.35V) the charging voltage is only 12.4V not 15V and it's slowly dropping not going up.
                                      Could this be possible reason for the board not to post?
                                      • mon2
                                        • Dec 2019
                                        • 14664
                                        49C
                                        That is toasty. Chip was replaced? Was the chip soldered in the proper orientation on the board?
                                        • m1ch43lzm
                                          • Mar 2019
                                          • 921
                                          • Peru
                                          #40
                                          It's NVDC design (Narrow VDC), see https://www.badcaps.net/forum/troubl...arging-circuit
                                          I agree with mon2, the BQ25700A is too hot, it's available at mouser if its determined to be faulty
                                          So the main power rail and battery charge voltage is dependant on the battery configuration, so for 3S battery the fully charged voltage should be from 12.6v - 13v, similar as the Macbook charge circuit with the ISL chips
                                          With battery unplugged you should get 12.6 or 13v
                                          Could be the main rail (VSYS15) is unstable?, that may be the cause
                                          • coasterghost
                                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                            by coasterghost
                                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                            System Hardware:
                                            Processor: AMD Ryzen 7 PRO 5850U
                                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                            09-08-2025, 10:46 PM
                                            Lenovo 3000 Series Schematic
                                            Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                            3000 C100 laptop with Braille keyboard
                                            Lenovo 3000 C
                                            C100, C200 - 15-inch XGA screen
                                            Lenovo 3000 N
                                            N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                            N500 - 15.4 inch screen.
                                            Lenovo 3000 V
                                            V100, V200 - 12.1-inch WXGA models
                                            Lenovo 3000 G
                                            G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                            10-04-2024, 06:05 AM
                                            Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                            09-06-2024, 06:40 AM
                                            This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                            09-06-2024, 06:06 AM
                                          • derradji89
                                            Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                            by derradji89
                                            Hi everyone 🤗
                                            I have a Lenovo MIX 320-10lCR computer.**
                                            1. **Operating System**: Windows 10 ** Education** 64-bit.
                                            2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                            3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                            4. **BIOS Chip Reflashing**: Currently,...
                                            04-19-2025, 03:04 PM
