Looking to learn about troubleshooting my Lenovo L14 Gen 1
  • eliasseverholt
    • Dec 2023
    • Sweden
    Hello!
    Unfortunately my Lenovo L14 Gen 1 (motherboard NM-C741) was involved in a terrible mishap. At first, one of my friends accidentally spilled coffee on it which made some of the ports stop working but the computer worked fine otherwise. After that I stupidly opended it and forgot to disconnect the battery... One thing leads to another and I accidentally short it between two components (unfortunately I do not remember which components). After that I get nothing, no charging indication, no boot indication, no fan spin, nothing.
    So I'd love to learn my mistakes and learn more about troubleshooting on component level. So far I have identified that the VSYS15 rail correctly supplies 9.2V, however I have also identified that I do not get any VCC5M or VCC3M.
    So far I've used this schematic along with a board diagram that I found online which has helped me locate the components.
    If anyone would have a step by step process of troubleshooting I would be very keen to know it. Also, in the case of a short between components, what component can I expect to be broken? Is it possible to somewhat predict?
    Looking forward for your replies!
  • eliasseverholt
    • Dec 2023
    • Sweden
    I did some more troubleshooting, the chip PU0501 which is responsible for creating the VCC3M rail gets incredibly hot (I guess a short somewhere). Anyway, I'll continue to troubleshoot
    • Lifeisfun
      • Apr 2025
      • 47
      Hi there, did you manage to find what was the problem? Facing the same issue on E15, same PU0501 chip is getting very hot.
      • mon2
        • Dec 2019
        • 14666
        Remove all power. No battery either. Meter in resistance mode. Measure the resistance to ground of PL0501 inductor which is the output of the PU0501 switching regulator. The resistance will confirm if there is a shorted part on this rail or not. Post the measurement in ohms. If your meter is not an automatic type, select a higher resistance scale till you have a measurement.
        • Lifeisfun
          • Apr 2025
          • 47
          Thank you very much for your reply!
          I attached schematic in that area with measurements (when I shorten my multimeter leads the meter is showing 0.2ohm)
          When power is applied there is 0V on the PL0501 inductor and 0.3V on pin 5 LDO
          The other pic is the chip it self with marking of the area where it starts to burn hot.
          Click image for larger version  Name:	PU0501 resistance.jpg Views:	0 Size:	146.5 KB ID:	3624287Click image for larger version  Name:	hot chip.jpg Views:	0 Size:	149.5 KB ID:	3624288
          • Lifeisfun
            • Apr 2025
            • 47
            I just compared to the 5V power supply chip, and that one even with 0V on the coil still provides 5V on the LDO pin also resistance measured on that coil is in kohm range unlike the 6ohms on the 3V coil.
            • Lifeisfun
              • Apr 2025
              • 47
              I took it step further and injected 2.8V/0,9A to the 3V rail and the PCH gets slightly warm (thermal cam pics) and the 3.3V chip still lights up like a charismas tree in the same corner.
ID:	3624354 Click image for larger version
              • mon2
                • Dec 2019
                • 14666
                So the ldo rail and all parts camped on this rail are suspects. If you feel comfortable, suggest to isolate the ldo rail by removing the pr0506 short (blue colour in the schematics) on the pcb. Then test which side is shorted. Is it the producer (regulator) side or the downstream (consumer) side that is with a short? The shorted part maybe the filter capacitor on this ldo rail. Do not power up till we learn more about the state of this rail.
                • Lifeisfun
                  • Apr 2025
                  • 47
                  Much appreciate your time trying to help!
                  I'm unfortunately unclear what the pr0506 marking means since it's not marked on the board it self.
                  Is it the jumper that is connecting board layers I marked on the pic on pin4?
                  Would heating it up and using solder sucker to remove it work?
Name:	board closeup PR0506.jpg
                  • m1ch43lzm
                    • Mar 2019
                    • 923
                    • Peru
                    Hi
                    That's a test point, what you suggest won't work in this case
                    I marked in yellow the "jumper", it's the wide part of trace itself next to the capacitor PC0515
                    I'd remove the ic in this case to check
                    • Lifeisfun
                      • Apr 2025
                      • 47
                      Originally posted by m1ch43lzm
                      Hi
                      Thank you!
                      Oh, Ok, I thought it will be some kind of removable jumper
                      Chip is out, now there is 48ohm resistance on the PL0501 inductor, 48ohm on pin4, but still only 1.9ohm on the LDO pin 5
                      • Lifeisfun
                        • Apr 2025
                        • 47
                        Now with the voltage regulator chip removed, is it safe to inject some voltage on the LDO pin 5 to see if there is anything burning?
                        I did check all capacitors on the board but didn't find any dead shorts, only the 1.9ohm everywhere on the VCC3SW line.
                        • m1ch43lzm
                          • Mar 2019
                          • 923
                          • Peru
                          Lifeisfun Your board model is FE4A0/FE5A0 NM-C421
                          From schematics found here https://www.badcaps.net/forum/troubl...38#post1555838
                          VCC3SW goes to the EC IT8227, you can check injecting 1v to confirm
                          • Lifeisfun
                            • Apr 2025
                            • 47
                            Sorry to ask over and over but I have very little experience with repair like this, and watching YT will give you only very little details.
                            When I injected 1V to the VCC3SW it takes about 400mA (my limit was set to 1A) The IT8227 temperature was about 27C and this was the only component on the board that warmed up.
                            Injecting 1V/1A to the VCC3M it took only 32mA and nothing was getting warm.
                            Can someone please experienced tell me if this does mean something?
                            Thank you folks!
                            • m1ch43lzm
                              • Mar 2019
                              • 923
                              • Peru
                              If it's drawing 400mA, VCC3SW is only supposed to handle up to 100mA
                              Try 1.5v on VCC3SW, if the current goes higher and EC gets hotter, you need a new one
                              EC needs to be programmed, you may find sellers on ebay/aliexpress which sell them preprogrammed, you need to give them the board model (NM-C421) and EC model (IT8227E-256)
                              Related topic about programming IT8227 https://www.badcaps.net/forum/troubl...to-it8227e-256
                              • Lifeisfun
                                • Apr 2025
                                • 47
                                Thank you very much for the diagnostic help and possible solution!
                                I guess it will be best for me to order preprogrammed chip, since I wouldn't use the programmer enough.
                                Did you ever order from someone who you could recommend?
                                • m1ch43lzm
                                  • Mar 2019
                                  • 923
                                  • Peru
                                  Did you ever order from someone who you could recommend?.
                                  Sorry, i can't give you a particular recommendation, I just search on aliexpress and ask the seller before buying
                                  you may ask other laptop repair shops near you that do motherboard repair
                                  • Lifeisfun
                                    • Apr 2025
                                    • 47
                                    Thank you!
                                    • Lifeisfun
                                      • Apr 2025
                                      • 47
                                      I have removed the EC chip and now the short is gone, my question is, can I reinstall back the 3.3V voltage regulator and test if it still works or this is not save move? or it will not work without the EC chip installed?
                                      I also learned that I will need to use the Lenovo utility (ThinkPad Config Information Update Utility) to add back the model# and serial number.
                                      This must be done immediately or I can do that anytime after if I get it to boot and work properly?
                                      Any particular version that is best to use? I found several versions and I'm not sure what is the one that should be used to create the USB drive.
                                      Thanks for all the help!
                                      • m1ch43lzm
                                        • Mar 2019
                                        • 923
                                        • Peru
                                        You can measure the regulator itself with multimeter if it's not shorted, according to the pinout from post #5
                                        Measure resistance to GND on the regulator itself, also test with diode mode on multimeter (red probe on GND, black probe goes to the other pins), post the readings
                                        I would look for new regulator SYX198BQNC, check the markings on the IC itself (RFxxx), get a pack of 5-10, they're cheap, sometimes you may get faulty ICs from china sellers...
                                        If you confirm it's not shorted, you should get back VCC3SW and VCC3M (and corresponding 5v rails if i'm not mistaken), remember that the LDO powers the EC so at least you should get the LDO output
                                        This must be done immediately or I can do that anytime after if I get it to boot and work properly?​
                                        I don't think you need to edit that info, as it's stored on BIOS chip, unless you flashed a different BIOS with external programmer (and don't have a backup of original BIOS in that case)
                                        Only the EC needs to be programmed, that's why i suggest to buy preprogrammed EC, as the programmers are expensive if you're not doing many repairs to justify the cost
                                        Laptop shouold power on and show image in that case, maybe an error message, i don't know the specific details on that model
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
                                        • derradji89
                                          Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                          by derradji89
                                          Hi everyone 🤗
                                          I have a Lenovo MIX 320-10lCR computer.**
                                          1. **Operating System**: Windows 10 ** Education** 64-bit.
                                          2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                          3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                          4. **BIOS Chip Reflashing**: Currently,...
                                          04-19-2025, 03:04 PM
