Macbook Pro 2018 dead with 5V 0A
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    • BalkanBoy
      Dead Razer Blade 14 2022, shorted CPU?
      by BalkanBoy
      today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
      Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
      I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
      Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
      I removed coil and injected 0.7V, it draw around...
      09-27-2024, 12:44 PM
    • vienzen
      MacBook Air A1466 EMC2925 (820-00165-A) Shorted PP3V3_S0
      by vienzen
      1. Problem of macbook is No Display
      2. Found shorted caps on c1212
      3. After removing the shorted caps (c1212) the reading in the c1212 pin1 is .003 in diode mode test, still shorted.
      4. Help me.....
      09-25-2023, 03:05 AM
    • tech_guru
      Macbook Pro 2019 A2141 NAND Shorted
      by tech_guru
      Hello. If you could please help me understand what I am doing wrong...
      This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
      I also replaced the tps power ic for the ssd.
      Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
      08-28-2025, 08:04 AM
    • jesi
      macbook pro a1707 dead
      by jesi
      hi all techs
      require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
      adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
      update:
      when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
      08-24-2025, 04:34 AM
    • Dylan Jones
      MacBook A2681 (Board 820-02862) - UP700 Likely Shorted
      by Dylan Jones
      I'm a beginner at laptop repair. I bought a MacBook Air A2681 that doesn’t turn on, just for practice. PPBUS_AON and the other always-on voltages are present and look fine. I did some diode mode measurements and got unusual readings (compared to reference values I found online) on LC320 (44mV) and L82D0 (40mV). LC320 corresponds to the PP5V_S2 power rail, and L82D0 to PP1V25_S2.
      I injected 1V (current limited to 100mA, the board consumed around 86mA) into PP1V25_S2 to see if anything would heat up, but everything seemed normal. I did the same with 5V (current limited...
      06-28-2025, 05:07 PM
