Tablet lenovo tb-x103f
  • samtron786
    • Aug 2016
    • 170
    • germany
    Hello
    Doesn't just start the screen goes on and off
    Home screen Empty battery with plug shows nothing more happens
    over 3.0 volts dancing
    Thank you
    • Jul 2011
    • 6070
    You need more than 3 volts in the first place check your battery voltage if is that low it needs to about 4.something volts to be considered fully charged it could be a battery issue or a charging issue
    You need to go into more details about what it is doing exactly and post some pictures of the screen if possible
    One possible solution is to disconnect the charging cable and push the power button for 30 seconds then hook up the charging cable an see if it resets it to start charging again you should see a battery icon in red and it might not boot until it has enough voltage on the battery to boot up and work correctly if you get this leave it in off position until it power on by itself or very quickly push the power button to see the state of charge and it is not red anymore
    One thing if possible take a picture of the battery and the battery power leads
    It would be helpful if you had a USB doctor that has a voltage and current meter on it to know if the tablet is charging the battery or not
    or
    Google how to do a hard reset for this tablet and follow the directions and see if that helps or not
    My son has a tablet from where he works and let the battery get so low that it was in a rebooting cycling mode and I did what I suggested above about one possible solution
    • samtron786
      • Aug 2016
      • 170
      • germany
      Hello, I have marked the location in the picture
      I have 1x 2x 3 full flashes here and doesn't stay stable. It's in motion
      the battery is not charging
      Thank you​
      • samtron786
        • Aug 2016
        • 170
        • germany
        I also changed the power adapter and cable, unfortunately that didn't help
        • samtron786
          • Aug 2016
          • 170
          • germany
          Another question, is there a circuit diagram for it?
            • 22265
            Post your request in the "Schematic requests ONLY!" sub forum -> https://www.badcaps.net/forum/troubl...-requests-only .Include the motherboard model number
            • samtron786
              • Aug 2016
              • 170
              • germany
              Good afternoon, thank you
              Model: A6505_PK85a is
              2917 H103C​
              • ferah831208
                Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                by ferah831208
                Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                03-18-2025, 01:18 AM
              • code share
                Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                by code share
                I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                Here's what I've tried so far:
                • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                • Booted successfully on AC power only with the battery disconnected
                • Visual inspection of the battery — no swelling, burn marks, or connector damage
                • Battery
                04-21-2025, 12:50 PM
              • Zibbo
                Lenovo T470P NM-B071P not charging, 20 volts on positive +ve battery terminal
                by Zibbo
                Lenovo T470P NM-B071P had no power. PQ2 and PQ11 were shorted, repaced them and laptop turned ON. Connected the battery and the motherboard turned off immediately and it won't charge, checked the voltages and found out that there is 20v on the positive battery terminal.
                Replaced battery charger IC PU101 and the two switching mosfets PQ101 and PQ102 and still same problem. Now I can't figure out how 20v is ending up on the battery terminals.
                12-27-2024, 12:20 AM
              • pabloroggeri
                Lenovo V310-15ISK - It doesn't work after changing the battery
                by pabloroggeri
                Good guys. I changed the battery to a Lenovo V310-15ISK.
                The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
                When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
                08-23-2024, 12:01 PM
              • dhs6512
                Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
                by dhs6512
                Hello. Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 board
                Initially dead. Inspection: the board was not touched, on EC IT8227E-192 2101-CXA there is a mini-burnout.
                Replaced with the same one, flashed the EC with the official firmware (had to solder to the pins), left the main firmware (Gigadevice 25LB128DSIG) original.
                When connecting the charger, the device started, gave picture and works, checked all the functions - ok.
                Connected the original battery. Only on the battery the device starts for a second, lights up the keyboard backlight and turns off.
                When connecting...
                10-29-2024, 11:04 AM
