hi, my hp 6735s giving 5 blink on caps lock then give display but not charging the bettery.
					HP 6735s 5 caps lockblink not charging
 Re: HP 6735s 5 caps lockblink not charging
 From what I understood on three different 6735s boards with the 5 blink problem, it occurs when there's a missing voltage on the board somewhere, possibly connected to the KBC chip. Just work through the schematic from the adapter and try and figure out what it is.
 Possibly something's happened to the comparator circuit?
 Interesting that it still boots though. Does it work fine on a charged battery then?Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
			by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
			by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
 Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
 Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
 System Hardware:
 Processor: AMD Ryzen 7 PRO 5850U
 Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM
			by esqmoooHello everyone.
 This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
 Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
 Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
 I tried long pressing on the power button, after several seconds it would go off then when the button is released...
			by esqmoooHi,
 I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.03-07-2025, 05:55 AM
			by ThomasraudHello,
 i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
 QUOTED
 -It works on charger (without battery connected-only charger)
 -It works on battery (without charger connected-only battery)
 -& it also works when plugged in battery & charger, but it's not charging the battery
 //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
 and..
 QUOTE
 The IC cannot maintain the input current level...
- Loading...
