List of pin compatible Laptop ICs
This is a sticky topic.
  • joselito
    • Mar 2015
    • 50
    • Philippines
    #161
    Re: List of pin compatible Laptop ICs
    HI
    is this IC have compatible replacement?
    G5616..
    thanks.
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      #162
      Originally posted by joselito
      HI
      G5616..
      thanks.
      Seem compatible with RT8207 family, just make sure the package TQFN3X3-20/WQFN-20L 3x3 or TQFN4X4-24/WQFN-24L 4x4
      compare its both pin out with according datasheet each vendor
      https://cdn.badcaps-static.com/pdfs/...6218c2ffb1.pdf
      https://cdn.badcaps-static.com/pdfs/...fa9f34c8a3.pdf
      • ahmad.qralh
        • Apr 2017
        • alkrak
        #163
        Thanks for sharing
        • oussama.elcheikh
          • Apr 2017
          • 34
          • Lebanon
          #164
          please hp15-d030se 03011NG00-600-G bios Please
          • annietronix ebay
            • May 2017
            • Nigeria
            #165
            Originally posted by highpulse
            max 8731ae , wich one can be compatible ?
            getting a similar one might be a hard shell to crack. I'd rather check in dell vostro 1000.
            • kadi144
              • Aug 2015
              • 690
              • algerie
              #166
              can i use a TPS51216 or BQ 727 as replacement of TPS 51716 in DELL INSPIR0N 15-3000
              • jbstokyo
                • Jun 2017
                • 6
                • japan
                #167
                Any RT9024PE replacement?
                • farman19
                  • Jul 2017
                  • India
                  #168
                  rt 8223b compatible ic???
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    #169
                    216-0774207 can replace 216-0771009, done just now on HP G62. It's a "newer" family too, likely based on the same architecture but it is seen as an upgrade - 6300 series vs 5400 series.
                    A working TV? How boring!
                    • Rashid36
                      • Aug 2014
                      • 59
                      • Saudi Arabia
                      #170
                      Dear All member i need help about this chip with number "2n=2m" or any website where i can find this code
                      • fddizon
                        • Sep 2011
                        • 555
                        • Philippines
                        #171
                        What is the board you're working at?
                        • dvitryv
                          • Aug 2017
                          • Russia
                          #172
                          2n=
                          https://cdn.badcaps-static.com/pdfs/...d7b1efab2b.pdf
                          • swapnil1996
                            • Aug 2017
                            • 5
                            • India
                            #173
                            Nuvoton sio npce795pa0dx alternate so that i can fix my dell n5110 laptop. And any one has pinout of this chip please give.
                            • RethoricalCheese
                              • Mar 2013
                              • 1518
                              • Estonia
                              #174
                              Can I replace 25Q80BV for example for 25Q64FV? First one is 8mbit, second 64mbit but otherwise should be the same.
                              • imranromi
                                • Jan 2015
                                • 1288
                                • Pakistan
                                #175
                                No replace 25q80bv =1mb
                                25q64fv=8mb if u replace any 3v 1mb chip is working.if 8mb replace same 3v working all.8mb some chip 1.8v working.
                                • age80
                                  • Jun 2013
                                  • 55
                                  • Greece
                                  #176
                                  Are HM70, HM75 and HM76 interchangeable?
                                  • Djosla
                                    • Dec 2012
                                    • 246
                                    • Montenegro
                                    #177
                                    you can replace hm70 with hm76 ,and vice verca, but keep in mind that hm70 supports only celeron and pentium cpu`s so if you have better cpu onboard it won`t work for it...
                                    • age80
                                      • Jun 2013
                                      • 55
                                      • Greece
                                      #178
                                      Thank you Djosla for the info!!!
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        #179
                                        Correction, original chip was 216-0774009 not 216-0771009. Writing was rubbed off a little.
                                        • nabi
                                          • Sep 2017
                                          • 15
                                          • algeria
                                          #180
                                          Thank you
                                          • Deby
                                            List of compatible laptop motherboards
                                            by Deby
                                            This is a list of compatible laptop motherboard information that I have been collecting for some time.
                                            And it's still ongoing.
                                            Every time I come across information that a board is compatible with another, I write it down.
                                            Anyone who wants to, can continue to expand the list.
                                            Packed in the rar, is an excel table that has additional information.
                                            Motherboards.rar...
                                            05-31-2024, 04:34 AM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:11 AM
