Toshiba C660D no power
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hi, i got this toshiba C660D. When pluged in green led is on. When press power buton fan spin for 1sec and then stop. I check all fuse and they are ok. i see no physical damage on board.
    PCB label is: LA-6843P des someone have schematic?? I use schematic for LA-6842P but it is not the same.
    ...the quieter you become the more you are able to hear...
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: Toshiba C660D no power
    I check all fuse, and check caps with multimeter continuity test. i managed to find some shorted caps. I desolder them all but they are ok. I cannot find where is the short circuit. I found that reading on ISL6251 AHAZ a bit of strange.
    Here are some pics.
    I check coil without removing them and they all pass continuity test.
    • whaldsz
      • Apr 2013
      • 395
      • Philippines
      you can desolder the jumpers (example, PJ2 in image #2) so you can isolate which section is causing the shorts.
      The short is not in the 19v rail right?
      If no component is heating up, try to check the coil going to the GPU. If shorted, disconnect the coil and check which side is still shorted. If the load side (going to GPU) is shorted, then you need to replace this bga chip.
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        I try to do what you told me to do, and i find that when PJ7 is desoldered i can turn on the board, fan spins both led stay green. Ofc i don't have picture but it a start. Only component that is heating up is GPU. CPU is cold.
        • whaldsz
          • Apr 2013
          • 395
          • Philippines
          That means the short is in the pj7 rail.
          • cyberhack
            • Feb 2013
            • 466
            • Uk
            Here you go
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              @cyberhack - thank you for diagram
              I think i found where is the short cut. But i want your opinion. In picture attached i marked red rail where i get short cut, i think this should not have to be connected.
              I found that Q13B - 2N7002DW-T/R7_SOT363-6 is N-channel FET, is it possible that that FET is bad? (page 31)
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                i desolder Q13B - 2N7002DW and it was ok, no shorts. i am confused
                • khaahk
                  • Dec 2013
                  • 760
                  • Estonia
                  Search for +NB_CORE in pdf. There is a possbility of northbridge short and there are some more caps (C180,C182...)also connected to the line.
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    i thik this is a northbridge short, i found on some other rails short. They all camo from NB.
                    I found shorted these on top of BGA.
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      What resistance are you calling a short? Some of those capacitors on the NB will measure about 20 ohms and some might even measure near 0 ohms. This is likely normal.
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        you are absolutely right! (rievax_60)
                        That made me think, and then I discovered that one MOSFET is shorted (in real therm SHORTED, GDS shorted) it was PQ41- MDU2653RH.
                        I connect PJ7 jumper back and it worked, i got the picture. I will order MDU2653RH although obviously laptop can work without it.
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          Well done.
                          Also that is why I sometimes say to not apply more than 1v test when finding a short. There might be a shorted High Side MOSFET sending the test voltage directly to CPU, NB or GPU.
                          • whaldsz
                            • Apr 2013
                            • 395
                            • Philippines
                            nice work rtstorm!
                            • tomodachi
                              • Apr 2012
                              • 602
                              • Turkey
                              well done ! Compal motherboards are can be easily repaired, and thanks for sharing.
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • GLISIT
                                by GLISIT
                                01-16-2025, 02:29 PM
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                              • ju123
                                Toshiba Satellite C50-A won't power down
                                by ju123
                                Hi guys,
                                So, I've been racking my brains on this one.
                                I have a Satellite C50-A which I'm repairing for a friend.
                                I recently replaced the main board due to failure.
                                Following this, absolutely everything works perfectly, except for the fact it won't power down.
                                Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning...
                                01-07-2022, 04:40 PM
