messed up LVDS on a acer 5920
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    Hi guys,
    I messed up LVDS connection on this laptop, hope you can help me out..
    It all happened when i was replacing the LVDS cable, and the replacement was shorted without my knowledge.. a spark came out, and when i replaced back the old cable it wasn't working anymore.. I have neither image or backlight.
    I thought it might be a broken fuse like in other laptops, but i've searched around and didn't find any fuse.. Do you guys know what i should check?
    Thanks.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
  • selldoor
    Slow Learner
    • 7870
    Re: messed up LVDS on a acer 5920
    perhaps pictures of the area around the connector would help and of
    the inverter board in the screen and perhaps the board if there is one on the
    back of the panel.
    Have you tried with an external monitor?
    If the cable is damaged and in place there doesnt seem much point in trying to fix the laptop as it will just blow again. Have you tried continuity testing each wire in the cable and also for shorts between the pins.
    • Learn2Day
      • Jun 2013
      • 254
      • Portugal
      Yeah, forgot to mention, VGA output is working fine.
      Not sure how pics would help, but the schematics might..
      http://www.electronica-pt.com/index....down/id,18113/
      Try Harder!
      • Learn2Day
        • Jun 2013
        • 254
        • Portugal
        Here's some pics.
        Thanks.
        Try Harder!
        • selldoor
          Slow Learner
          • 7870
          I am not good on schematics but better at pictures. I was looking for components that might blow like a fuse.
          Perhaps test the zero rated resistors for continuity - ones with 000 on.
          • Learn2Day
            • Jun 2013
            • 254
            • Portugal
            These resistors have continuity. I also checked connector for 3 and 5V, and it's present.
            Thanks.
            Try Harder!
            • selldoor
              Slow Learner
              • 7870
              OK after checking the cable for shorts and breaks think you need to get into the inverter board then - may be a fuse on it?
              • khaahk
                • Dec 2013
                • 815
                • Estonia
                Did you leave the battery connected while changing the cable?
                VIN voltage on R9 present?
                LCDVCC on pins 3&5 present?
                • Learn2Day
                  • Jun 2013
                  • 254
                  • Portugal
                  It's not the inverter cuz i was using a different inverter/screen/cable when it happened..
                  18V in R9, and 3V present in pins 3&5.
                  Thanks.
                  Try Harder!
                  • selldoor
                    Slow Learner
                    • 7870
                    Sorry I dont follow this.
                    1- you had a laptop which didnt output to the laptop screen ?
                    2- you decided to try a different lvds cable
                    3- cable was faulty.
                    So why would it work with the old cable.inverter.panel when it didnt work before?
                    I think we are going to need a more detailed step by step of what you were doing and why.
                    • Learn2Day
                      • Jun 2013
                      • 254
                      • Portugal
                      Let me explain you a little better..
                      The laptop screen was working fine but had a couple of green lines on the right side, in a stupid (very stupid) quick move to rule out board i jumped the gun and inserted spare replacements (screen, inverter and cable), when i did this charger power went down, and up again when i touched the LVDS connector. thinking it was a bad contact i touched it again, it sparked and got busted.
                      Hope this helps.
                      Try Harder!
                      • selldoor
                        Slow Learner
                        • 7870
                        Hope this helps.
                        OK when you unplugged the old panel and lvds from the mainboard the
                        laptop was up and running?.
                        In which case is it possible that when you unplugged the old screen a surge
                        blew a fuse on the inverter board. That might explain why when you plug it in now it doesnt work.
                        Any further plugging/unplugging should be done with the power off and the
                        main battery removed.
                        If you are sure the new screen is the same or at least compatible then
                        again if you plugged it in when the laptop was powered up it could have caused a surge which blew fuses on its inverter board and caused the
                        charger to cut out.
                        Also just to be sure I am assuming its not possible to connect the lvds
                        upside down.?
                        • tomodachi
                          • Apr 2012
                          • 612
                          • Turkey
                          if you fail at all methods, prepare to replace the KBC chip
                          • Learn2Day
                            • Jun 2013
                            • 254
                            • Portugal
                            It's not the inverter. If it was the inverter i would have image and no backlight.
                            tomodachi, what's tha KBC chip?
                            Try Harder!
                            • tomodachi
                              • Apr 2012
                              • 612
                              • Turkey
                              [/IMG]
                              • Learn2Day
                                • Jun 2013
                                • 254
                                • Portugal
                                Wouldn't that chip affect VGA output as well?
                                Thanks.
                                Try Harder!
                                • tomodachi
                                  • Apr 2012
                                  • 612
                                  • Turkey
                                  Thanks.
                                  No it doesn't I guess. But it affects backlight.
                                    Acer Aspire A515-57-5920 Notebook 5 Specification for Upgrade or Repair
                                    This specification for the Acer Aspire A515-57-5920 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-57-5920 boardview and A515-57-5920 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-07-2024, 07:20 AM
                                    09-06-2024, 05:27 AM
                                    Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                    This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    09-07-2024, 05:00 AM
                                    Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                    This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                    Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                    This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-07-2024, 04:10 AM
