I have a Gateway NV7317u that will not past post. It gives a blank screen and no external screen will work. The power light will light up and the HDD will spin up and stay spinning. But the fan will start then stop after a few seconds. The light on the power supply says a green light. I have the motherboard out and did not see any damage. Anyone have any ideas on how to fix or listing of chips on the motherboard that may go bad?
					Gateway Nv3717u not posting
	Tags: None
 Re: Gateway Nv3717u not posting
 Nothing will display on the screen and no beeps are heard as if it was getting to post. And the reflow is the first step i tried and it is still giving the same issues. Anyone know if there is a listing of the chips and the placement for this board?Comment
 maybe a bad ram stick or ram socket
 try one stick at a time in both socketsComment
 I have tried a combo of 4 different ram sticks and I have tried a reflow on the gpu. It is the same no matter what socket the ram is inComment
 try this and see if it fits.. .good luck! Attached FilesIm Back... sort of... Attached FilesIm Back... sort of... Comment
 Is there a way to try to reflash the bios with out getting anything on the screen to see if that may be it?Comment
 I figured it may have been the gpu chip, just have to find an easy way to remove itComment
 So I was testing some of the led light bars, and found out the touch media bar that allows for the volume to be muted or turned up and down will still work. seems like it may be the vga chip. Anyone know of an easy way to replace the chip on a DIY level?Comment
 I have worked on that before. Reflow will not work as two pins (balls) or more are touching each other. You will need to reball those chips. Since those chips are so thin, you need the right temp to remove and replace or else you will damage the IC.
 Good luck!Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer Comment
 Do you know of a good way for me to fix it from home. With out having to spend a lot of sending it to have the chip reballed?Comment
 So does anyone know what size solder balls to use for this chip for a reball?Comment
 Still not having any luck finding out what size solderballs to use on the gpu. Do anyone know what size is needed? And a good place to order themComment
			by sam_sam_samI have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
 I also have back when Light of America had these light bulbs available for yard lights
 The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
 While the Lithonia lighting fixture has all most certain bulb failure
 So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
 I have only had this light fixture for not more than a year if it...
			This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
			This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 09:10 PM
			This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 08:40 PM
			Hello Everyone!
 I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died....06-28-2025, 02:57 PM
- Loading...
