dell 1558 fm9b mainboard
  • pwll computer services
    • Dec 2012
    • 3
    hi
    have a studio 1558 (FM9B MAINBOARD )
    no power but does charge battery ,anyone have any suggestions or better still a schematic (must be fm9b not fm9)
    andrew
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: dell 1558 fm9b mainboard
    power adapter or power jack. Dells like yours use two power rails, one to charge, one to run
      • Dec 2012
      • 3
      dont think it is power socket as the always 5v and 3.3v are working
      • bucephalus
        • Mar 2016
        • 22
        • India
        Originally posted by pwll computer services
        hi
        andrew
        My laptop have similar problem but on battery there is no 3.3v and 5v alw could you please share your experience if you have fixed this problem.
        • diif
          • Feb 2014
          • 6978
          • England
          Check continuity of power button cable.
          • bucephalus
            • Mar 2016
            • 22
            • India
            Hi
            Thanks for the quick reply
            I have tested miniature tact switch and the cable. they are good and shows continuity. When I press the power button led on the button blinks for 1/2 second then nothing happens. The Charger is working properly and charging the battery. On battery connector 12 volts are present and the charging jack led turns on. I request you to kindly read the complete problem as I have posted it here https://www.badcaps.net/forum/showpo...3&postcount=13
            • bucephalus
              • Mar 2016
              • 22
              • India
              The power switch have 2.7v instead of 3.3v.
              • bucephalus
                • Mar 2016
                • 22
                • India
                Motherboard have +3v_alw and +5v_alw when connected to AC Adapter but +15w_alw is absent i am unable to understand why? I have checked several components but i am unable to locate the faulty one. please help.
                • Oj computer
                  • Dec 2021
                  • 38
                  • Nigeria
                  Pls I also have issue with the same board.
                  It doesn't power.
                  I have 19v at the gate of the second MOSFET instead of 3.3
                  And the LDO is not present at the pin 21 of the charging ic (pu4) and I've changed the ic still no changes.
                  Kindly help me sir
                  • mon2
                    • Dec 2019
                    • 13870
                    Measure and post the voltage readings for:
                    DCIN
                    LDO
                    pins on the MAX8731A (PU4). The LDO does not have an enable pin so it should be always ON.
                    • Oj computer
                      • Dec 2021
                      • 38
                      • Nigeria
                      Dcin 19v
                      ldo 0v
                      • mon2
                        • Dec 2019
                        • 13870
                        Remove all power.
                        Meter in resistance mode. Check the resistance to ground of the LDO pin.
                        What is the measurement and meter scale?
                        • Oj computer
                          • Dec 2021
                          • 38
                          • Nigeria
                          Thanks for glur great response sir.
                          Resistance to grand of LDO pin is 641
                          • mon2
                            • Dec 2019
                            • 13870
                            What is the meter scale?
                            The measurement is 641 ohms ?
                            That is a low reading for the LDO rail. Confirm it.
                            Consider the remove the capacitor on this rail and check if the resistance changes to a higher value.
                            • Oj computer
                              • Dec 2021
                              • 38
                              • Nigeria
                              After removing the two capacitors connected to the LDO rails.
                              The reading changed to 632 ohms
                              • Mirenia
                                Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                by Mirenia
                                I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                03-30-2025, 06:47 AM
                              • MahmoudNasser
                                Dell Vostro 3400 battery does not charge beyond 55%
                                by MahmoudNasser
                                I have a Dell Vostro 3400 battery does not charge beyond 55%
                                I tried another file... the battery charge exceeded 55%, but it entered manufacturing mode and it did not count from it.
                                - I rebuilt the basic BIOS and Clear Me, but without results
                                What if the same situation does not charge the battery more than 55%?
                                Can someone help me?
                                The original BIOS file is attached
                                Device Data
                                Model Dell Vostro 3400
                                CPU:i5-11th
                                SN 7G4BRF3
                                MP PartNumper:LA-K032P REV 1.0 (A00)
                                Bios Chips:XM25QH64A...
                                10-09-2023, 03:58 PM
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
                              • diamon
                                Dell 5590 LA-F412P does charge with USB-C not with DC-Jack
                                by diamon
                                As mentioned, I have a Dell 5590 laptop with motherboard LA-F412P.
                                This laptop works with the USB-C charger and not with DC-Jack charger.
                                With the USB-C charger attached, the battery is charging and in the BIOS the charger is also recognized.
                                With the DC-Jack charger attached (USB-C charger removed), the light of the charger is not going off and the BIOS does not see the charger (message AC Adapter = Not installed). I'm using original Dell chargers and I have tested the used chargers on other Dell laptops and they are working correctly.
                                I have replaced the DC-Jack,...
                                12-29-2023, 07:29 AM
                              • reeluff
                                DELL XPS 15 9510 LA-K411P (NVDC ISL9538C) NO BOOT / NO CHARGE
                                by reeluff
                                Device history > Bit of liquid damage, that I cleaned up and sorted out all bad components.
                                Current state > No Boot. No charge. It negotiates 20v on all USBC ports, and will even PD charge out – so all of the USBC circuit is probably ok. I have 3.3V + 5V ALWP present and stable. PCH has its 3V,1.8V,1V. On the board, PCH,EC,ISL,PD chips are all powered on and active. Power button has 3V, board is being signalled by it but not responding. I have 20V USBC in OK, I have a 12.6V main power rail ok. The battery was undervolt dead, so had to manually charge each cell individually...
                                02-09-2024, 09:37 AM
