Toshiba C660 IGp chip get really hot.
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    Hi I am working on a Toshiba C660 and the IGP chip gets really hot, the fan is running constantly. I have measured the temp at 67c dos anybody know if this is normal also I cannot find any short circuit caps around it but there are 2 caps on the igp itself reading short. I suspect the Chip may be faulty, what do you guys think ?.
    The set is running normal just very hot.
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Re: Toshiba C660 IGp chip get really hot.
    which version bios have?
    • Bisketti
      • Oct 2013
      • 252
      • Ireland
      The Bios is v1.00 and ec Version 1.00
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        Old... download 1.50 bios and ec
        • Pragmatiko
          • Jul 2013
          • 468
          • IT
          • Bisketti
            • Oct 2013
            • 252
            • Ireland
            Latest version is 1.3 ec and bios so updated both and still very hot @ 65c.
            • Pragmatiko
              • Jul 2013
              • 468
              • IT
              Replace thermal compound
              • Bisketti
                • Oct 2013
                • 252
                • Ireland
                I have tried that also placing copper shim aswell I think maybe the IGP chip itself is faulty.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Does it work fine? Let it be.
                  A working TV? How boring!
                  • Bisketti
                    • Oct 2013
                    • 252
                    • Ireland
                    I like your sentiment.
                    • spleenharvester
                      • Mar 2010
                      • 902
                      Pretty sure if there were shorted caps it would not function at all.
                      Honestly, some IGPs do run that hot. Maybe a dodgy thermal sensor? I guess the only way to be sure is if someone else with a C660 with that motherboard chimed in.
                      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        try to clear cmos by removing battery... helped me few times...
                        Im Back... sort of...
                        • Bisketti
                          • Oct 2013
                          • 252
                          • Ireland
                          I have already Updated the bios and the ec using external programmer, but maybe its normal just seems strange it would be that hot with the fan running constantly. Whats the best util for monitoring temp of Gpu? would speedfan do it ?.
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            aida64
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Hm, how hot is the air that is coming out of the fan/heatsink thing? It could be possible that the heatpipe isn't working as well as it should be.
                              Muh-soggy-knee
                              • jtamad44
                                • Apr 2013
                                • 145
                                • israel
                                it losses the gas inside sometimes if there is a leak, may be need to change the heatsink.
                                • spleenharvester
                                  • Mar 2010
                                  • 902
                                  As above. Even if it is getting too hot, I seriously doubt this is a motherboard problem. Try replacing the heatsink.
                                  • Bisketti
                                    • Oct 2013
                                    • 252
                                    • Ireland
                                    Thanks for the input folks. I didnt know heatsink had gasses inside the copper pipe.
                                    • masud
                                      • Jul 2011
                                      • 317
                                      • Bangladesh
                                      reflow or replace the igp chip is the only solution i think.
                                      • infringer
                                        Badcaps Member
                                        • Sep 2009
                                        • 244
                                        • United Frickin States
                                        lol no it is just hot air... sheesh there are no gases ...
                                        What does happen though is that:
                                        A) there is not a even surface on the chip or the heatsink
                                        B) there is build up between the fan output and the copper pipe
                                        C) the solder has become faulty
                                        D) The chip has issues itself
                                        I would check for the build up of crap I have seen this ruin more laptops than anything you will not see it until you remove the fan from the heatsink in many cases it is crazy the amount of stuff I have found on some laptops with bad motherboards it is like someone brushed their pets winter coat off while working on their laptop then what happens is instead of working like a cooler it works as a heater!
                                        Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
                                          09-06-2024, 05:27 AM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • DynaxSC
                                          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                          by DynaxSC
                                          Hi
                                          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                          08-04-2025, 12:20 PM
                                          by SMDFlea
                                          Bad...
                                          09-02-2021, 04:40 PM
                                          09-06-2024, 05:59 AM
