HP G62 +5VPCU and VIN shorted
  • sonunigam
    • Aug 2013
    • 151
    • Pakistan
    Hello All members,
    I'm in a very critical situation that I'm repairing a HP G62 Which was dead and no light in Power Jack. I checked the voltages on Battery Connector, It shows that 4.8 Volts on +Positive. I Looked closely that KB3926QF D2 is short so i changed the IC. but now when i checked the +5VPCU and VIN the motherboard showing short. I removed the KB3926QF D2 but still same. I remove Processor but still same. I almost one by one remove and checked all IC's and FET's but it still shows short. Plz anyone can help that which is the thing is Shorted. I'm very upset for that. . . . .
    I'll Appreciate if anyone can help me out. . .
    Thanks to all
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: HP G62 +5VPCU and VIN shorted
    Originally posted by sonunigam
    Hello All members,
    Thanks to all
    what do you mean "KB3926QF D2 is short ", Did you compare with schematic, do you have standby voltages such as 3.3v and 5v, did you check resistance of coils to ground ? did you check protection circuit and charging circuit ? ...
    • sonunigam
      • Aug 2013
      • 151
      • Pakistan
      Hi Spidey,
      first of all, i checked PC116 which is for +3VPCU was short, When i remove KB3926QF the shortage was gone. Now there're no Standby Voltages nor 3.3V neither 5V. I've checked PL4 with GND and resistence shows 37.3 Ohm. and PL2 shows 13.0 Ohm. I've checked Charging IC PU6 ISL6251A is ok. Where is the Protection Circuit? Will you plz tell me? I'm gonna uploading the Schematic Diagram so plz guide me to get rid off shortage. . .
      By the way would you like to tell me that what is the meaning of +3VPCU or +5VPCU Please?
      Thanks a lot
      • bowor
        • Oct 2013
        • 36
        • indonesia
        hi sonunigam, I can be the same case with your voltage is +5 vpcu short. usually are in need voltage is 5v power ic vCore (isl6262) it likes short, usb driver. try to check it!
        • sonunigam
          • Aug 2013
          • 151
          • Pakistan
          Hi Bowor,
          I'll check PU1, by the way thanks for your reply. . . .
          • Francisco.s
            • 686
            • Spain
            When i remove KB3926QF the shortage was gone. Now there're no Standby Voltages nor 3.3v
            If you remove KB3926QF, then, S5_ON signal is removed also, so, some voltages needed in S5 state are not there.
            Put a new embedded controller, and check voltage on power button and in pin 8 of 1M byte SPI EC ROM. (u13)
            Before that check PU5 and its main output pins. (if it is correctly powered)
            In this particular case, +3VPCU= +3VALW
            • spidey
              climbs
              • Dec 2012
              • 644
              • Cyprus
              +3VPCU AND +5VPCU are your standby voltages, it is normal that you dont have any standby voltages after you removed EC. Ec gives on/off signal to standby circuit. Be carefull when you replace KB3926QF xx with a new one, you have to solder correct version of this chip, like KB3926QF C0, KB3926QF D1.
              it should be the same with the one desoldered. if charging is ok, probably protection circuit is ok. But after changing EC, i would also change rt8206b and check mosfets and caps around.
              • sonunigam
                • Aug 2013
                • 151
                • Pakistan
                Hey Bowor, I've checked ISL6262, it is ok. not shorty, I'm very upset that how to remove shortage. And Spidey why you asked that check Resistance the coils with Ground? Plz plz plz anyone can help me that how can i remove shortage. . . I think i've checked the whole motherboard for get rid off the shortage expect North bridge and south bridge. . . .
                Plz anyone can help that how to do that?
                • bowor
                  • Oct 2013
                  • 36
                  • indonesia
                  now, where the condition motherboard short? is it still on track vpcu +5, or where? I am usually to handling his is short, by injecting gave the 5v voltage, if it is short on the 5v line (see schematics). then I feel around the area where a hot hand. it usually causes short.
                  if no vpcu +3. could be caused from ec. try to re-solder all the legs ec. ec it works if you get a voltage of +3 v_aux_s5 derived from ic charger. easy way to check the voltage of +3 v_aux_s5 can pin battery, 1,7,8 feet of ic bios.
                  good luck!!!
                  • Francisco.s
                    • 686
                    • Spain
                    Why don´t you post your measurements?.
                    What about rt8206b, mosfets and caps around?
                    • sonunigam
                      • Aug 2013
                      • 151
                      • Pakistan
                      hi all,
                      I just want to know from all great and experienced technicians, that plz see the schematic diagram and help me out to solve this kind of shortage. I told to all of you that the shortage between +5VPCU and GND. I've a Multimeter which has a buzzer, When i connect Red and Black probe to each other, The buzzer is beeping. It's mean when +5VPCU is short with GND, the buzzer is beeping. . . Now tell me you all that how can i tell about the readings? Plz get rid me off from this mess. . . . .. I'm waiting for the reply.
                      • sonunigam
                        • Aug 2013
                        • 151
                        • Pakistan
                        One more thing that RT8206 is not generating 5v and 3v. Because the circuit is short. . . . .
                        • Francisco.s
                          • 686
                          • Spain
                          hi all,
                          You must use the ohms scale, not the buzzer. If readings are > 5 or 10 ohms, then there are no short-circuit.
                          • sonunigam
                            • Aug 2013
                            • 151
                            • Pakistan
                            Especially Francisco.s, Thanks for your great help. Now i checked with ohms and the PL4 is showing 00.2 Ohms. Now plz tell me what should i do? ? ?
                            • sonunigam
                              • Aug 2013
                              • 151
                              • Pakistan
                              Hey guys,
                              At last i got it, PC159 is faulty. but 3.3 or 5v are not generating by motherboard. Now i've to see more to find out why the Volts are not generating. . huh
                              BY the way thanks for your great replies. . .
                              • Francisco.s
                                • 686
                                • Spain
                                Hey guys,
                                If 3.3 or 5v are not generating by motherboard, check +VIN on pin 2
                                of capacitor PC85 in order to know if PU5 is correctly powered.
                                quanta ax3 winbledon ax3.5 - da0ax3mb6c2 ddr3 - rev 1a
                                • OOF DIO
                                  ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                                  by OOF DIO
                                  (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                                  (Had 3 problems, now just 1)
                                  I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                                  I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                                  I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                                  04-19-2025, 05:03 PM
                                • Geeker007
                                  9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                                  by Geeker007
                                  Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                                  I am new to electronics repair, so my queries could be naive but I am ready to learn.
                                  So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                                  01-28-2025, 03:31 PM
                                • kotel studios
                                  Lenovo B50-70 LA-B092P REV 2.0 - short on +3VLP
                                  by kotel studios
                                  My lenovo B50-70 laptop (mainboard compal LA-B092P VER 2.0) had a short on the +3V generation part (where PU401 is).
                                  I've removed the SY8208BQNC and the short is gone on PL402. Although, it's still there on pin 5 "LDO" of the SY8208BQNC (1.8ohms to GND).
                                  All other coils aren't shorted to GND.
                                  Removing the PC412 cap didn't help. Mainboard pads are still shorted. Cap itself is fine.
                                  Pin 20 (+3VLP) of ALC codec isn't shorted too, so it shouldn't be the issue.
                                  Originally, the laptop wouldn't power on. It would get its 20V on the...
                                  10-12-2025, 03:32 AM
                                • DynaxSC
                                  Extreme High Current & Low Voltage Short Killer ??
                                  by DynaxSC
                                  Hi Folks
                                  I'm looking for a extreme high current short killer solution for a reasonable cost.
                                  I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                  After taking off the socket, the shorts dissappear again.
                                  The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                  10-15-2024, 10:13 AM
                                • Achille15
                                  Dell N5110 problem
                                  by Achille15
                                  so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
                                  03-29-2025, 04:41 PM
