[help]ASUS F5SL MOTHERBOARD: SOLDER PIN!
  • phantomEVO
    • Mar 2013
    • 488
    Re: [help]ASUS F5SL MOTHERBOARD: SOLDER PIN!
    for one pin it says
    "u3101" Pin:15 NET: NC__2022 ICT:"
    for one pin it says
    "u3101" Pin:15 NET: NC__2027 ICT:"
    • Francisco.s
      • 686
      • Spain
      Originally posted by phantomEVO
      i've opened this boardview with tsict...(this program has a strange translation with a lot of "????" and not word...however i've opened the file and so?
      Can`t you see the printed circuit and the components?
      I think it is a program developed in China, so it is normal what you see. ("????")
      • glovecaps
        by glovecaps
        11-25-2024, 04:23 PM
      • dhenion
        Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
        by dhenion
        I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
        The original board was:
        ASUS X510UNR REV 3.0 A
        The replacement board is:
        ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
        It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
        01-30-2024, 01:45 PM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • MakNCheese
        ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
        by MakNCheese
        I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
        Symptoms:
        • Severe lag across the system, including BIOS navigation.
        • Slow boot times and unresponsive performance in Windows.
        • Battery charges very slowly (e.g., ~5% in 2–3 hours).
        • No error messages or BSODs, just extreme sluggishness.
        What I've Tried:
        • Replaced
        06-04-2025, 12:48 AM
