ASUS K50IJ with lp156wh2 no backlight in led
  • nalle077
    • Mar 2009
    • 102
    Re: ASUS K50IJ with lp156wh2 no backlight in led
    Here are photos of mainboard. one of each side of area with dc jack.
    Best regards Nalle
    • sorinac
      • Jul 2013
      • 123
      • Romania
      measure this diode and check if it is shorted
      if shows 0 ohm then is faulty and you need to change it
      also the computer should work without it but you must be careful next time
      • nalle077
        • Mar 2009
        • 102
        The diode shows 58,1 when multimeter is set to measure max 200K.
        And that is from both sides? when I measure black on one side and red on other. and same thing if you switch sides on probes.??? should only go one way, right???
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          You must take diode from the board and test it with diode test. You shoud have reading i one way and not in the other way.
          ...the quieter you become the more you are able to hear...
          • nalle077
            • Mar 2009
            • 102
            Ok. But does it sound like the diod is the problem? It is not shorted then? What is next thing to check? Do you think I should take out diod from bord?
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              #26
              not necessarily, take it off the board and test with diode test on your multimeter
              • nalle077
                • Mar 2009
                • 102
                #27
                Hello. I have been busy this weekend but now I took the diod of the board and did a measure. It shows no reading in any way. You wrote earlier that it should work without it. But if it have no reading I understand the diod is broken, but shouldn't it work. Or do you mean it should work but not charge. What is the correct diod to buy? There is someone selling electronic parts in my town. What do I need?
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  #28
                  i think this is the diode you need
                  http://www.ebay.com/itm/SS0540-SMT-M...item5aea91b1e0
                  • nalle077
                    • Mar 2009
                    • 102
                    #29
                    Hello again. I have changed the diod, but the laptop does not charge anyway. What is next thing?
                    Regards nalle077
                    • nalle077
                      • Mar 2009
                      • 102
                      #30
                      Regards nalle077
                      Hello. Anyone with an idea?
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        #31
                        check coil L8101 for 5V L8102 for 3V
                        • nalle077
                          • Mar 2009
                          • 102
                          #32
                          I can not find them. Can you please help me with the location?
                          Best regards nalle077
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            #33
                            it can be on other side of board, U8101 can be on one side and this coil on other. Check carefuly
                            this is how it look
                            Or post a good quality photo of MB in both side
                            • nalle077
                              • Mar 2009
                              • 102
                              #34
                              this is how it look
                              I have found them I think, but do not know which of them you mean.
                              Here are pictures.
                              First overview and then closeup
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                #35
                                one of this is L8001 and L8002, look for printed text near this coil
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  #36
                                  or you could find this QFN IC, and check for voltages pin 16 and pin 25
                                  • user546087
                                    Keyboard backlight too bright - Asus Zenbook S16 / UM5606
                                    by user546087
                                    I have a new Asus Zenbook S16, Model UM5606. Unfortunately, the keyboard backlight is too bright, even on the lowest setting. I have explored several ways now:
                                    - kindly ask Asus for an adjustment - they basically told me to STFU and get lost It is not possible, they say. Of course.
                                    - tint the keycaps from behind - I have already tried that - it is kind of a last resort
                                    - try to find out, how it is done, look at schematics - this is, where we are at.
                                    - maybe get the BIOS modified somehow? This would be the best option but I do not know a lot about...
                                    02-24-2025, 02:03 AM
                                  • FallenOne008
                                    Asus G712L No Screen Backlight
                                    by FallenOne008
                                    Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                                    The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                                    03-31-2025, 08:27 PM
                                  • obdcart
                                    Asus X415ea Adding a Keyboard with Backlight
                                    by obdcart
                                    Hello my friends i hope you can help me, i have just replace a keyboard with non backlight on a Asus X415 Laptop and i already install a Keyboard with backlight, the motherboard has the conector and ic's to control the light but i doens't work, i already try with a new installation of Windows and it's the same and injecting 3v/5v to the backlight flex it turns on the light, i think must be disable on Bios or need a jumper configuration.
                                    I hope you can give me some help
                                    06-28-2024, 02:21 PM
                                    ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
                                    This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                                    09-07-2024, 01:00 AM
                                  • grimacelord
                                    by grimacelord
                                    07-10-2025, 02:52 PM
