Hi I have a odd problem that I am stumped with at the moment. I recently went to switch the main screen on a dual screen w701ds and now it will no longer stay on if the lcd cable is plugged in? It boots up just fine if the cable is unplugged. The cable itself is fine. My friend who needs his unit back asap is willing to pay for a new motherboard ;however , if the new screen somehow shorted the board I don't wont to repeat that event. When I changed the screen out the battery was not installed and there was no power to the unit. Does anyone have experience with these dual cable screens is there some simple step I am missing? Any thoughts or help would be much appreciated.
					Lenovo w701ds won't power with lcd cable attached.
 Re: Lenovo w701ds won't power with lcd cable attached.
 try replacing lcd panel first if LVDS cable has no short. i think that screen is shorted that is why the mobo does not start with the cable on.
 one way to check if LVDS cable is short is to connect just the cable to the mobo without the screen panel. if laptop wont start, cable is shorted. if it works, lcd panel is shorted.
 hope this helps
 Thank you for your reply fddizon. That's the strange thing the laptop only posts without the cable even the new cable with no screen attached. There was no power to the board or battery installed when I switched screens. When powered with the new screen there was no odd metal contact to cause a short and no smell or spark. The old screen worked before I exchanged them. I believe the problem is with the board and I will likely order a new one but I don't wont to repeat the event that damaged the board the first time. My guess is that the new screen was the cause. How would I test just the screen?Comment
 Check the pins in the LVDS socket. I've had LVDS pins bend together a few times and cause all sorts of weirdness.Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSDComment
			by PantherDaveHi all!
			by olliec420Ok I screwed up big time and hoping I can fix. I will break down what happened and the images.- Have Dell PowerEdge R730
- Bought Tesla P40
- Researched power cables and order correct one, pic had two black connectors in photos
- Power cable arrived, same connectors (EPS-12v) on both ends
 Both sides are the same plug but different colors. The listing stated that colors would be random. OK I plug it in, red side to riser board, black side to GPU.
- Power on.
- System immediately turns off.
- I only had 1 PSU plugged in and it was blinking orange, I thought I drew too much so I plugged in
 11 Photos
 Assuming...7 Photos
			by Mita99Hi,
 Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
 Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
 Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
			by Dr.dI have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
 Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
- Loading...
