Need help with a Acer 5740 board I picked up:
Symptoms when received:
- 1 Would not power on with AC only (Ac Adapter (PS) light flickers NOT STEADY)
-2 Powers and posts on with battery only
3- Worked with AC and Battery pluged in but no charge light
I was thinking AC Plug so I removed it but I see not shorts in plug
Then I go ahead and do a Continuity test on pins on ac Adapter on board and
have weird results:
All pins ground / mounting holes and POsitive pin all show they all connected to each other. I believe Positive should not show up as connected to ground pins correct?
How do I go about fixing this and hat is the cause? is it damage to traces on board at ac adapter connector or other componets.
have weird results:
