Acer Aspire 5750-6845 dead
  • tibimakai
    • Jan 2012
    • 3680
    Re: Acer Aspire 5750-6845 dead
    At:
    pin #8-Vreg3= 3.273V
    pin #13-EN= 1.965V
    pin #17-Vreg5= 4.964V
    • tibimakai
      • Jan 2012
      • 3680
      Any ideas?
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        Reading looks ok on those pins. Try to press the power button and check if you get voltages at pl4 and pl5. If you get normal voltages, led lights should turn on.
        • tibimakai
          • Jan 2012
          • 3680
          I did that, and nothing happened.
          • whaldsz
            • Apr 2013
            • 395
            • Philippines
            Does pin32 of u20 goes low whn you press power button? Voltage of your cmos battery?
            • tibimakai
              • Jan 2012
              • 3680
              I will have to check on these, when I get home. The battery, if I remember well I have measured and it wasn't to low.
              Pin32 is the command for ON/OFF?
              • tibimakai
                • Jan 2012
                • 3680
                It goes from 0.001V to 0V.
                Battery is 2.88V, but I have pit another one and it didn't make any difference.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Anybody can help?
                  Thank you
                  Tibor
                  • whaldsz
                    • Apr 2013
                    • 395
                    • Philippines
                    #29
                    Voltage at Pin 1, 6, 12, 19?
                    • tibimakai
                      • Jan 2012
                      • 3680
                      At pin #1, 6 I'm getting 0V.
                      At pin #12 I'm getting -0.003V
                      At pin #19 I'm getting 0V
                      • whaldsz
                        • Apr 2013
                        • 395
                        • Philippines
                        #31
                        You get no voltage at PL4 and PL5 because pin 1, 6 or ENTRIPx is 0v.
                        Measure the voltage at pin 2 of PQ25, EC_ON pin 2 of PQ27.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          There is 0V on all three pins(on or off).
                          • whaldsz
                            • Apr 2013
                            • 395
                            • Philippines
                            #33
                            VL is connected to VREG5, so you should have 5V at pin2 of PR64. Check if PQ24 and PQ25 is ok.
                            • whaldsz
                              • Apr 2013
                              • 395
                              • Philippines
                              #34
                              Measure resistance of PQ25 from pin2 to ground. If you get a short here then either of the two transistor is defective. You may need to pull them out and test out of circuit to confirm.
                              • kev4eva
                                • Mar 2012
                                • 37
                                • jamaica
                                #35
                                i have a same model with 19volts in however missing 3 vreg and 5vreg....will use these steps to see what is exactly fault as am stuck myself.Same symptoms dead an no led or activity.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  But, probably yours doesn't have a damaged USB port(the one with the remote PCB mini board).
                                  I will check soon those transistors. Thank you for helping.
                                  I'm repairing LCD/LED TVs also. I have just repaired a 46" LED Westinghouse.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    It seems that I had a bit of problem and I haven't noticed it in time.
                                    The negative wires were broken off at the DC in plug.
                                    Now I have 4.82V, 0.011V and 0V at pin #2.(PQ25)
                                    Still no voltages at the U20.
                                    PQ24 is a 6 pin little IC.
                                    • whaldsz
                                      • Apr 2013
                                      • 395
                                      • Philippines
                                      #38
                                      Where do you read 4.82v? What are the voltages at pin 1-6 of PQ24?
                                      Also what are the voltages at the pins of PQ26. The gate is connected to EC_ON and comes from ENE KB930.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        On pin#1(base) I have the 4.286V(sorry I had it wrong).
                                        It seems to high for base, no?
                                        Collector pin#3 is 0.011V.
                                        I don't know which one is pin#1 at PQ24.
                                        If I look at the markings on it, from the readable side, I start writing the pin voltages from bottom left side toward right and going up and toward the left side.
                                        pin#1=0V
                                        pin#2=0.011V
                                        pin#3=1.118V
                                        pin#4=0V
                                        pin#5=0.11V
                                        pin#6=1.54V
                                        PQ26
                                        pin#1=0.005V
                                        pin#2=0V
                                        pin#3=4.286V
                                        • whaldsz
                                          • Apr 2013
                                          • 395
                                          • Philippines
                                          #40
                                          Looks like your voltage readings on PQ24 is ok. Why? there is a voltage at the SOURCE of both mosfet(see ) that is enough to put ENTRIPx high and make VOUTx to give 3.3V, 5V at PL4, PL5, provided pin13 EN Of PU2 is also high.
                                          On PQ26, the result is odd. 4.286V is for pin 1 right?
                                          One more time, could you please measure all voltage at the pins of PU2 for confirmation before you change this IC?
                                            ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 03:28 PM
                                            ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 02:30 PM
                                            ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 05:27 AM
                                            ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
