Acer Aspire 5750-6845 dead
  • tibimakai
    • Jan 2012
    • 3680
    Re: Acer Aspire 5750-6845 dead
    The 4.286V is on the base(single pin) of the transistor.
    I will check those voltages on the U20.
    Where would I find this IC if I have to buy it? Ebay?
    • whaldsz
      • Apr 2013
      • 395
      • Philippines
      #42
      This reading looks normal.
      • tibimakai
        • Jan 2012
        • 3680
        At U20 is all the same, basically is 0V on all those pins.
        So, I guess I need to change this IC?
        • lorins_core
          BlackSmith
          • Dec 2012
          • 552
          • Philippines
          #44
          About The U20. Can You Check if they Have Open Connection in PIN? or Try To Resolder...
          • tibimakai
            • Jan 2012
            • 3680
            Could you please be more specific? I don't really follow you.
            • lorins_core
              BlackSmith
              • Dec 2012
              • 552
              • Philippines
              #46
              Ok... sorry. About The U20. They have A Pins. Take A Look Proper. If you Have A Electronic Microscope Better can Check The Pins To Connection Edge on board. Maybe They Have Corroded Or Cold Solder. You need to Resolder. or if You Have A HotAir Reworks Station Remove the IC and Clean The Terminals and Re install The IC (U20)
              • tibimakai
                • Jan 2012
                • 3680
                OK, thank you I understand now.
                I have USB microscope and hot air station too. I will give it a try. It looks scary though. It will be my first time soldering something with so small pitch.
                I may try just reheating it first.
                This would be the IC?
                http://cgi.ebay.com/ws/eBayISAPI.dll...:X:AAQ:US:1123
                • whaldsz
                  • Apr 2013
                  • 395
                  • Philippines
                  #48
                  U20 or PU2?? Of course you still dont have the 3.3v and 5v you wont get any voltages at U20.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Originally posted by whaldsz
                    Measure the voltage at pin 2 of PQ25, EC_ON pin 2 of PQ27.
                    I was re reading these posts and I don't remember measuring PQ27. I had measured PQ24 and PQ26. It matters at this point?
                    U20. I don't know what is PU2? You said to recheck the voltages on U20.
                    • whaldsz
                      • Apr 2013
                      • 395
                      • Philippines
                      #50
                      Looks like your voltage readings on PQ24 is ok. Why? there is a voltage at the SOURCE of both mosfet(see ) that is enough to put ENTRIPx high and make VOUTx to give 3.3V, 5V at PL4, PL5, provided pin13 EN Of PU2 is also high.
                      On PQ26, the result is odd. 4.286V is for pin 1 right?
                      One more time, could you please measure all voltage at the pins of PU2 for confirmation before you change this IC?
                      I am referring to the above post. Measuring pin32 of U20 (see post #25) no longer matters because surely, you don't have any voltages there. U20 gets its supply from +3VALWP on PL4 found in the circuit of PU2.
                      Could you measure. The voltages at all pins of PU2?
                      Also measure the resistance with respect to ground of PL4 and PL5.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        OK here are the voltages:
                        Pin #
                        1= 1.53V
                        2= 0.065V
                        3= 1.998V
                        4= 1.998V
                        5= 0V
                        6= 1.114V
                        7= 0V
                        8= 3.27V
                        9= 4.5V
                        10,11,12= 0V
                        13= 3.17V
                        14= 1.998V
                        15= 0V
                        16= 19.22V
                        17= 4.96V
                        18= 0.065V
                        19= 4.96V
                        20,21= 0V
                        22= 4.472V
                        23= 0.001V
                        24= 0V
                        • whaldsz
                          • Apr 2013
                          • 395
                          • Philippines
                          #52
                          Since pin 19 is HIGH, clearly it's in OverVoltage Protection (see datasheet of RT8205 on page 23 under the section OUTPUT OVERVOLTAGE PROTECTION (OVP) ).
                          1. Check PQ21 if defective.
                          2. Check resistance across PL5 and ground.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            PQ21, PQ20 and PQ34 are shorted between pins 1,2,3 and 4.
                            PQ33 it's OK.
                            Between PL5 and ground there is only 100 Ohm.
                            Between PL4 and ground, there is only 0.6 Ohm.
                            Doesn't look good.
                            • whaldsz
                              • Apr 2013
                              • 395
                              • Philippines
                              #54
                              So the overvoltage is caused by a short in PL4.
                              When you tested PQ21, PQ20, and PQ34, did you test between Source [123], Gate 4, and Drain [5678] - pins 1 2 3 and pins 5 6 7 8 are connected together?
                              Anyway, remove PL4, check resistance between the two pads to ground - this is to locate if the short is in the load side (+3VALWP) or the MOSFET side (PQ22, PU2).
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Pins 123 and 5678 are connected together. Between 5678 and 4 there is no short. Short is only between 123 and 4 on all three transistors.
                                Later I will remove PL4 and I will test it.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  OK, the short is not toward the FETs. At PC42 side is the short. At the +3V ALWP.
                                  • whaldsz
                                    • Apr 2013
                                    • 395
                                    • Philippines
                                    #57
                                    See page 56 of the schematic diagram, it will help you isolate the short.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Unfortunately, I'm lost in this schematics.
                                      I don't understand from where is coming that 3V?
                                      • whaldsz
                                        • Apr 2013
                                        • 395
                                        • Philippines
                                        #59
                                        +3VALW comes from +3VALWP on page 46 through jumper PJ7.
                                        On page 56, you see that +3VALW supplies many sub-circuits - +3VALW_PCH, +3V_LAN, +3VALW_EC, +3VS and +3V. You just need to isolate those circuits and test the resistance to ground, just like what you did to PL4.
                                        Simpler way is to use a variable DC Power supply to identify the shorted component. Set the voltage to 0.3v and solder the +wire to +3VALW and -wire to GND. Start with 0.3V and gradually increase the voltage until you notice the heating shorted component. Be careful not to set the voltage too high or you end up damaging other components. There are tutorials on youtube for additional reference on this topic.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          I didn't get to far, didn't have much time, but looking at the block diagram and trying to find those components, I hit a road block.
                                          Pages noted in there, do not match the service manual(a,b) and for example on my board is missing U14. U21 has only one Q25, not two as in the service manual.
                                          U21 has all the 5,6,7,8 pins together shorted to the ground(0.6). The other pins are fine.
                                            ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 03:28 PM
                                            ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 02:30 PM
                                            ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 05:27 AM
                                            ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
