FSC Amilo LI 3910 no backlight
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    I'd like some help in diagnosing this laptop here. The display gives picture but the backlight works only sometimes, mostly it doesn't. When it works the picture is clear and bright. I'm not sure if it's the ccfl, inverter or the mainboard that's faulty. The machine is 4 years old and it's actually rarely used.
    Measuring the inverter's input cord shows 10.6-11.2V 2.5V 3V GND. Interestingly there is a clean 12V supply voltage form the motherboard. Checking the wires continuity shows that the flat wire that comes from the motherboard and the other that goes to the inverter are not connected (no resistance measured).
    I have some experience with laptop displays and it would be really embarassing to get the wrong replacement part for this one.
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: FSC Amilo LI 3910 no backlight
    Measured voltages looks ok. Try known good inverter and a screen to find which is faulty. Probably, problem is ccfl. it is bad or, corrupted cable soldering.
    • pdavid
      • Jan 2011
      • 279
      • Hungary
      If the ccfls are faulty then I'll just pass. Those are built into the display panell and cannot be swapped. l'll get some working ccfl and test the inverter to see what happens.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Are you sure you cant take the panel apart to replace the ccfl lamps?
        Muh-soggy-knee
        • pdavid
          • Jan 2011
          • 279
          • Hungary
          Well, as I see the frame assembly is welded together and filled with some hard glue or resin around the ccfls. No screws, clips or anything.
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
            Fujitsu AMILO Amilo Pi2530 - T5250 P Specification for Upgrade or Repair
            This specification for the Fujitsu AMILO Amilo Pi2530 - T5250 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Amilo Pi2530 - T5250 boardview and Amilo Pi2530 - T5250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 05:27 AM
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
          • cheebster
            iPad Pro 12.9 5th Gen Backlight Issue
            by cheebster
            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
            Anyone...
            05-20-2025, 09:17 AM
