hi to all here i just want to ask if any 1 can help me to find schematic for this model and if any 1 can help me to fix this laptop its dead cant charge the battery cant even power on its some kind of spilled of liquid in keyboard...thanks in advance here is the detail of mobo DA0ZR7MB8F0 Rev:F hannster J MV-4 94V-0
Acer aspire 5745DG power problem plz help!!
Re: Acer aspire 5745DG power problem plz help!!
it is quanta ZR7. -
i finish cleaning the mobo and i check the current around the board some caps have v19 some v16 and other v3.3 v0.1 v8.0 and i dont know how to check mosfet or other component.. is this board have fuse ? thanks again for the responseComment
to check the current, connect your multimeter serial to power plug in (DC) A mode. You should see 0.01A while in standby mode. if it is higher than 0.003A, that means there is problem. Btw, check +3v +5v circuit coils, to see +3.3v and +5V exists. then measure on/off button if there is 3.3v, and press the button, is it going down to 0v ? Also check cmos battery. You have some voltages on caps so you dont need to worry about fuse. Btw it should be around power plug.Comment
Are you sure, you are japan ?ok, switch your multimeter to DC Current (A) mode, cut the power adapter (+) cable, then connect your probes to cable serially. Btw you must connect probes to correct place on multimeter. is it clear now ?
PS: sorry for not updating any progressComment
its been a long time...im here again to ask for your help!! i never done fixing this laptop if any one here have a good heart willing to teach me or help me to fix this dead laptop just like spidey did i really thank you..Comment
I have myself had a keyboard spillage that killed a laptop dead until I removed keyboard and up it started, then I just had to buy new keyboard
good luckComment
I have the same problem with my laptop it works four Six hours then it turns offComment
Just cook it! It's already broken.Comment
Hi guys sorry for posting this up on this thread but i need help ....
I am trying to fix an emachines D440 with AMD v120 Processor and ATI Radeon HD 4520 it switches on and takes about 0.96A and does not display. I did BGA on on the IGP but still the same no changes. anyone got ideas.
please HELP..Comment
1. Try measuring the voltages across the big capacitors first, see everything has the correct voltages.
a. if voltage reading is missing, you have your clue.
2. Measure pin 22 of mini card WLAN if you get 3.3v when powered on. if this is missing check the ICH/PCH/Southbridge.
post what your results.Comment
whats the condition of missing?
No voltage only if adapter its in without pressing power button?Just cook it! It's already broken.Comment
This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...09-12-2024, 03:28 PM
This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...09-12-2024, 03:28 PM
This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...09-06-2024, 05:27 AM
by DenKDear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down...
Dear All,
Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power.... - Loading...
