Hp nc6400: No Power - Dead
  • speedypro
    • Feb 2013
    • 561
    Hi all.
    Im here again working on a hp nc6400. Its basically dead. I've opened it up and found a burnt ic: "LM393" (PU25). It was replaced but laptop still remains dead.
    DC jack is ok and testing various points on the board we are able to get the 19v.
    Any pointers? Bad bios chip?
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Re: Hp nc6400: No Power - Dead
    do you have bios file for this laptop? I'm having no display issue today. It was working 2 days ago I was ready to install fresh OS but never booted. My version is intel based video. I visited hp's website found bios category but don't know which one I would load.
    hope you have thanks!
    • whaldsz
      • Apr 2013
      • 395
      • Philippines
      load the oldest one.
      • lezsimply
        The Wanderer
        • 645
        • Philippines
        This is the link from hp website, all files are on the same date. There are 4 different files with different file size. I assuming to load the file which have .84mb in size having intel video description. Is this the correct one? thanks!
        http://h20566.www2.hp.com/portal/sit...achetoken#BIOS
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
          03-31-2024, 02:12 PM
