acer aspire one kav60 no power
  • alihomee
    • Dec 2012
    • 1577
    • malaysia
    i have this acer aspire kav60 with no power.voltages are ok at dc jeck and 6 voltages are present at power switch and they goes to 0 when i press it.i also check around pu4(tps 51427) no voltages only 8v at pin 5. then i check around pu10(tps 51610) nothing. so where should i check now.i already tried by reflashing bios but same.when i pluge in from dc power supply the power supply shows nothing. can have any ideas
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: acer aspire one kav60 no power
    first find the schematic. Also measure current on standby.
    • gabik111
      ORD spotter
      • 142
      • USA / Poland
      Well , I had similar but there was a BIOS issue. If you flashed BIOS and still nothing looks like you gut long walk ahead...
      Laptops and computers repair.
      • Francisco.s
        • 686
        • Spain
        Hi, I have this schematic, if you need it, I´ll post for you.
        • alihomee
          • Dec 2012
          • 1577
          • malaysia
          so please send
          • cyberhack
            • Feb 2013
            • 466
            • Uk
            Here you m8
            • kenttech16
              • Oct 2011
              • 27
              • Philippines
              Yup! It won't work because it has no power so you can't enter the bios recovery with crisis disk. It applies, not always but some aspire one with power but no display even you've done the usual stuff isolate memory stick and adapter.
              You need to check the standby volts from power switch and also the bios, most likely it 's windbond.
                ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                09-12-2024, 03:28 PM
                ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
                This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                09-06-2024, 05:27 AM
              • DenK
                Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                by DenK
                Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                12-06-2024, 01:29 AM
              • Bonaventure Vigil
                ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                by Bonaventure Vigil
                Dear All,
                Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                12-12-2024, 10:22 AM
