AC adapter MOD ?
  • primoz1
    • Oct 2010
    • 270
    • Italy-Slovenia
    AC adapter MOD ?
    I got HP AC power for laptop and work on DELL ok, but not charge battery and when I try to upgrade BIOS got notice like "change for DELL AC power" and stop BIOS upgrade program, for this dell i cant find USB version BIOS file, and maybe there will be the same problem.
    I see one time "dont remeber which web site" how guy make modification on HP AC power to charge DELL battery.
    Is anyone know more about this ?
    Thank you.
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: AC adapter MOD ?
    i work with lab type power supply, and if i connect it directly to dell or hp i have similar problems. But, i use around 120-180k resistor connecting between middle pin and +19v and it works. But also in dell laptops bios, you can bypass ac adapter type errors.
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • mikeybass
      by mikeybass
      04-23-2025, 04:30 PM
    • capoplays
      Help with BIOS update on Dell G15 5515 after chip replacement
      by capoplays
      Hey everyone,
      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
      When I check the BIOS using the F12 menu Flash...
      10-24-2025, 06:53 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • Sathsul
      Dell Latitude 5431 issues with dumping bios
      by Sathsul
      So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
      The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
      However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
      Yesterday, 07:49 AM
