CQ56-130SY USB problem.
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Bought a laptop that needed a little work - I had to change LCD and keyboard. Ok, those got changed and are working correctly.
    But now I discovered there is a problem with USB.
    When I connect a device, it says the device is not recognized.
    Only device it works with, is my plain old keyboard. None of my mice and USB flash drives are recognized.
    I tried reinstalling drivers, turning the laptop off, removing battery and holding down the power button for a long time. Tried removing the battery (basicly clear CMOS) but none of it fixed the problem.
    Then I took out my USB hub that had an external power source. Wired it up to my laptop and tried it with flash drives - everything worked perfectly.
    So it seems like there is a problem with the power. Does anybody know a fix to this or atleast any idea where could I find a place to "steal" 5V from the motherboard to power USB devices.
    Or what exactly distributes power to USB sockets?
    I tested the voltage - reads out 5.08V which is nearly perfect.
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: CQ56-130SY USB problem.
    I found an 8 legged creature near USB sockets, which is burnt.
    It is marked U8 on the motherboard and M113 on the IC itself.
    Could somebody tell me, what IC it is exactly? Or maybe offer me a schematic for this laptop?
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      desolder ic, short pin2 and pin 8 on the bord. it should work.
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Okay.
        Actually I found out 2 things - the same IC is on the third USB board and it is not M113. It is actually G547F2.
        • mockingbird
          • Dec 2008
          • 5484
          Here you go:
          https://cdn.badcaps-static.com/pdfs/...0dec09f5f8.pdf
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            Thanks!
            Edit: Problem fixed. Thanks again!
            • spidey
              climbs
              • Dec 2012
              • 644
              • Cyprus
              Originally posted by The_Boss
              Thanks!
              How did you fix it ?
              • RethoricalCheese
                • Mar 2013
                • 1519
                • Estonia
                Removed that shorted IC and soldered a wire to pin 2 and 7 (straightest way).
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
                • perzyk23
                  Lenovo T580 - LCD Panel problem - error 0288
                  by perzyk23
                  Good morning,
                  I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                  10-25-2024, 12:42 AM
                • lazaro.089
                  Asus Zephyrus M16 / GU603ZW problem
                  by lazaro.089
                  Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                  CPU: Core i9-12900H
                  Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                  Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                  The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                  08-26-2025, 06:33 PM
