HP 6715s - very odd issue
  • spleenharvester
    • Mar 2010
    • 902
    Hey all. Posted this again here in the appropriate section. Other thread can be deleted.
    I have a water damaged HP 6715s motherboard here.
    It works and boots fine into Windows!
    But ONLY IF leg 1 on Q75 is bridged with the DC jack's ground.
    Full schematic here: http://www.mediafire.com/?a317h9te1hxup3e
    I replaced Q75 to only meet the same problem. I thought Q75 was faulty since the multi read 1 on one leg, but it does the same to other identical transistors on the board.
    So presumably, something that's meant to lead to ground, has given up?
    Water damage was only confined to a very small 3x3cm square on the underside of the board, as residue. The spillage had long dried up.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 902
    Re: HP 6715s - very odd issue
    What the heck?
    I just shorted Q75 with DC jack-in by accident. Giant plume of smoke comes up from mosfet Q18, I think oh crap, this thing's done for.
    The board now works perfectly, while one leg on Q18 has literally blown off..?
    What even?
    • katzcaps
      • Feb 2012
      • 48
      Sounds like its fixed to me!
      • spleenharvester
        • Mar 2010
        • 902
        Hahahaha I really have no idea what to do with it now, can't seem to get hold of the exploded mosfet anywhere either! Ah well
        Are there any equivalent replacements around for this?
        • Tuomo
          • 163
          • Finland
          Deleted Message
          • spleenharvester
            • Mar 2010
            • 902
            Cheers for the info mate.
            Any idea what I could change Q18 with? I can't get hold of an FDS6673BZ at any good price!
            Thanks again
            EDIT: It's just struck me, maybe Q18 was at fault all along. I guess we may find out.
            • Tuomo
              • 163
              • Finland
              Thanks again
              This is possible, I have to make sure at I understand correctly that circuit.
              • spleenharvester
                • Mar 2010
                • 902
                It's leg 4 that's blown off for the record. I'm guessing either C43 or R75 would be the other two candidates for being at fault for the initial problem.
                R75 appears fine and reads in at ~21.8kOhms, C43 reads in at 350ohms resistance, but after discharging, doesn't recharge in the opposite direction as per this thread https://www.badcaps.net/forum/showpo...45&postcount=4
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  it looks like, first it was a protection circuit error, but now q18 is short.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Is Q75 connected while you are doing this?
                    I doubt R75 is bad - it is a 220K resistor - that would take a high voltage (hundreds of volts) to burn that sucker!
                    I think you should try replacing Q18. It could have been shorted D-G, and so when you shorted out Q75 (assuming you shorted it's D and G together), a large current flowed through Q18 and burnt out pin 4 (the G of the MOSFET).
                    Muh-soggy-knee
                    • spleenharvester
                      • Mar 2010
                      • 902
                      Q75 is indeed connected. It was a brand new replacement too so should be okay.
                      I've gone through my trashed motherboard stack and found a FDS6679!. It seems to be very similar to the FDS6673BZ. Worth a go?
                      EDIT: Also found a FDS6670S:
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        That could work, but it has a slightly higher on-resistance, a slightly lower continuous current (13A vs original 14.5A), and a lower pulsed current rating of 50A vs the original's 75A rating.
                        Your FDS6670S won't work because it is an N-Channel MOSFET, not a P-Channel!
                        I would say it is worth a try.
                        EDIT: The FDS6679 is lacking a gate-source voltage clamp! Not sure if that would be a big deal...
                        Muh-soggy-knee
                        • spleenharvester
                          • Mar 2010
                          • 902
                          Also just found an FDS6675A but it looks further off to me:
                          If it's no better I might give the 6679 a try.
                          Cheers
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Cheers
                            It isn't better, it has a lower current rating than the 6679, and higher on-resistance.
                            Muh-soggy-knee
                            • spleenharvester
                              • Mar 2010
                              • 902
                              Hmm. I'll look through some more scrap boards later and see if I can come up with something closer, even if it's not a Fairchild FET.
                              Also, if anyone is in the UK, and is after a really oddly specific part, feel free to PM me - I have quite a few trashed boards.
                                20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                by sam_sam_sam
                                I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                04-09-2023, 08:04 PM
                              • ugamazing
                                by ugamazing
                                12-17-2024, 07:05 PM
                              • Askic
                                Erratic touchpad behavior - ground issue
                                by Askic
                                Hello guys,
                                I'm having almost exact same problem like described here.
                                There is also a youtube video about this issue, but remedy suggested in the video doesn't help in my case.
                                When charger is connected, the touchpad starts with its erratic behavior. So it must be the ground issue. I'm not sure I understand exactly how to solve this.
                                Can you please have a look at the attached picture of the touchpad and suggest what to do exactly to try this solution?
                                In my case it is Acer M3 laptop and not Asus, but the symptoms are the same. Without...
                                08-19-2021, 03:44 AM
                              • elmark
                                HP 15-cw1002ua strange keyboard issue
                                by elmark
                                HP Pavilion 15-CW1002UA
                                S/N 5CD0251CBC
                                P/N 7KE54EA
                                Hello guys!
                                I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                It powers on OK and has no other issues except the following:
                                • CAPS LOCK does not work at all
                                • Fn button toggles Flight Mode
                                • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                • (with SHIFT pressed: 't%' and 'y^' respectively)
                                I initially thought it was a keyboard malfunction (internal short, etc.),
                                but when I press and hold...
                                06-27-2025, 01:10 AM
                              • obelix24
                                Macbook air a2681
                                by obelix24
                                Got this macbook air that was not working.
                                after opening i found water damage on LID sensor, daughter board (where keyboard connects) and trackpad
                                There was spilled probably coffee (i’ve cleaned everyhting with pure water and afterwards with isopropyl alcohol
                                i’ve disconnected LID sensor, repaired flex on trackpad (the part thet connects to trackpad there were some pads heavy corroded to i’ve repaired them) and i was able to put macbook to DFU and restore.
                                but the keyboard was not working at all (no caps lock light). After dfu was done i’ve connected external keyboard...
                                11-27-2024, 12:35 AM
