Lenovo 3000 Y410 won't boot
  • tibimakai
    • Jan 2012
    • 3680
    I was given this laptop to look at it if it's fixable. It's an old one bad in very nice shape.
    When I plug it in, one blue LED turns on between the mouse buttons.
    When I start it up, the fan turns on, the HDD light comes on for like two seconds and then the laptop shuts off. It seems like the mobo those it's thing, no?
    On the screen, nothing shows, not even the backlight.
    Did not come with HDD and power adapter. I have used just a random HDD around the house, not even sure if there is a Windows on it or not. HDD spins up though.
    It has a 1GB ram on the top slot.
    I have took it apart and found one of the USB port's pins(all 4) pushed in against a big SMD diode. Didn't seemed that they were touching any metal surface.
    I have found the CPU lock half way tight, so I have removed it, cleaned it and applied new paste and re-installed it, no change.
    I have checked any obvious fuses, voltage regulators and they seem fine.
    Power adapter is from another laptop, which I had around the house. 19V/3.42A.
    Not sure what else can I do with it.
    It's my first laptop repair attempt. I'm mostly, at the TV/monitor section on this forum.
  • Nocta
    • Mar 2012
    • 117
    • Argentina
    Re: Lenovo 3000 Y410 won't boot
    I had a similar problem with a Compaq laptop. The solution was doing a reflow on the video chip.
    • tibimakai
      • Jan 2012
      • 3680
      I thought that the video chip issue is an HP problem.
      • tibimakai
        • Jan 2012
        • 3680
        No other inputs?
        Can be CPU?
        • trebo
          • 514
          • Wales, UK
          Originally posted by tibimakai
          No other inputs?
          Can be CPU?
          well worth swapping Cpu if you got one
          even ram, also try botom slot
          those bent Usb pins you mention, you say they are not touching any metal, hope they are not touching each other as well
          you can remove hdd if suspect, it should still come up with a cant find error thou
          • tibimakai
            • Jan 2012
            • 3680
            Already tried the bottom memory slot, but I haven't swapped the memory yet with another. Will do it.
            The USB port may have had a short in the past, since all four pins were pushed in. Could this cause this problem? I'm think it could. The 5V is there though.
            HDD is just a random HDD that I had. PC did not come with one.
            If the graphics chip had problems, it shouldn't show any image on an external monitor? This one doesn't show anything.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              check the CMOS battery if it failed the display may not work but the rest might.
              Follow the white rabbit.
              • tibimakai
                • Jan 2012
                • 3680
                The voltage is 2.7V.
                • trebo
                  • 514
                  • Wales, UK
                  I agree with you, but that applies to the Cpu and ram as well
                  • spidey
                    climbs
                    • Dec 2012
                    • 644
                    • Cyprus
                    there are some possibilities, one of the secondary voltage regulator is short or a circuit is short connected to them. discrette or onboard vga needs reflow.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I could try re-flow too, but I have never done it before. There is a good how to somewhere?
                      • Nocta
                        • Mar 2012
                        • 117
                        • Argentina
                        In the first place, you'll need flux and a hot air gun, do you have them or do you know someone who can borrow them?
                        If you do, you'll have to disassembly the laptop. Cover the motherboard with aluminium foil except for the video chipset. Then heat for 3 minutes at 230ºC.
                        http://www.youtube.com/watch?v=tjWXExWM4RU
                        When you assembly back again your laptop, remember to use thermal paste!
                        Good to know but I think that pretty unlikely to happen, especially the CPU.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I have everything that is needed. I repair TVs and monitors.
                          What I do with the flux?
                          The laptop is already taken apart completely.
                          Unfortunately I don't have another memory or CPU. It has dual row memories, most likely is a low density type memory.
                          Those SMD caps on the chip and on the bottom of the mobo won't move away by heating it up the chip? I guess I have to use very low air flow.
                          • Nocta
                            • Mar 2012
                            • 117
                            • Argentina
                            Yes, sorry.
                            Spread flux on the sides of the GPU. When you heat it, it'll melt and get under the GPU.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I have tried the reflow, but it didn't change anything.
                              It must be something else. I will look for another CPU on Ebay, maybe I can pick one up for a couple of bucks. Maybe even a memory.
                              Cmos battery voltage is 2.6V, should I replace it? It should be 3V.
                              • spidey
                                climbs
                                • Dec 2012
                                • 644
                                • Cyprus
                                2.6v is enough.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I have purchased an upgrade one, T7250 for $5.38 shipped.
                                  This laptop uses PC2-6400 memory, but it seems that even PC2-5300 should work also.
                                  I may have some of those.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    The laptop is running fine.
                                    I'm not sure, what fixed the problem though.
                                    I was using all this time an external monitor. Today when I have seen that is not turning on the monitor, I have tried it, with it's own screen and it worked.
                                    Now I don't know if the re-flow, or the replacement CPU fixed it.
                                    In the BIOS, it was selected only the laptop display, it wasn't on the Auto select.
                                    Important is, that is running.
                                    Thank you all who helped me.
                                      LENOVO 3000 J110 3000 J E6300 Specification for Upgrade or Repair
                                      This specification for the LENOVO 3000 J110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 3000 J110 boardview and 3000 J110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO 3000 J110...
                                      09-12-2024, 03:36 PM
                                      Lenovo 3000 Series Schematic
                                      Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                      3000 C100 laptop with Braille keyboard
                                      Lenovo 3000 C
                                      C100, C200 - 15-inch XGA screen
                                      Lenovo 3000 N
                                      N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                      N500 - 15.4 inch screen.
                                      Lenovo 3000 V
                                      V100, V200 - 12.1-inch WXGA models
                                      Lenovo 3000 G
                                      G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                      10-04-2024, 06:05 AM
                                    • Luke Anders
                                      Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                      by Luke Anders
                                      A few details about the laptop itself:
                                      Name: Lenovo Legion 5
                                      Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                      BIOS Version: GKCN60WW
                                      EC Version: GKEC65WW
                                      Serial Number: PF39AQ7Z
                                      Board Model: NM-D562 Rev 3.0
                                      RAM: 16GB Installed, DDR4 (brand new)
                                      NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                      I bought this laptop recently from eBay as a faulty device....
                                      10-12-2024, 05:13 AM
                                    • Max029
                                      Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                                      by Max029
                                      I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                                      I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                                      TY,
                                      08-18-2024, 08:28 PM
                                    • q2v5
                                      Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                      by q2v5
                                      Lenovo T480s
                                      Model 20L8-S3TE00
                                      Board ET481-U10
                                      Chip MX25L12873F
                                      Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                      2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                      The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                      08-15-2024, 10:40 PM
