msi cr400x
  • lantech01
    • 6
    • philippines
    msi cr400x
    auto shutdown.....
  • chadot
    • Jan 2012
    Re: msi cr400x
    no display?
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      Re: msi cr400x
      replace proadlizer cap with 4x 330uf tantalum caps
      just fixed msi CR400. replaced it with 2x 330uf and 3x 220uf.
      works fine now with windows 8.
      see mega toshiba mega thread
      • lael1972
        • Mar 2013
        • brazil
        Re: msi cr400x
        hello,
        My CR400 also turns itself off in the middle of the boot, the video function normally. I'm waiting for motherboard die to test this solution of capacitors ...
        • fddizon
          • Sep 2011
          • 555
          • Philippines
          Re: msi cr400x
          Originally posted by lael1972
          hello,
          dont wait for it to die. just replace the proadlizer capacitor. nothing to loose though...
          • lael1972
            • Mar 2013
            • brazil
            Re: msi cr400x
            you're right!
            I'll arrange this as soon as possible repair and I report the results ...
            • tomodachi
              • Apr 2012
              • 597
              • Turkey
              Re: msi cr400x
              And if u need a schematic diagram just pm me, just in case
              • kenttech16
                • Oct 2011
                • 27
                • Philippines
                Re: msi cr400x
                strongly agree!!! most cases like this same with Toshiba Satellite L300 series thread.
                • rickybucalan
                  • May 2013
                  • 322
                  • philippines
                  Re: msi cr400x
                  hey men can i have this diagram thank you.
                  • tomodachi
                    • Apr 2012
                    • 597
                    • Turkey
                    Re: msi cr400x
                    sure I can but first you or someone have to teach me how to upload pdf to this forum
                    • cruiser_
                      A1466 820-00165 intermittent shutdown
                      by cruiser_
                      hi there,
                      Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
                      Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
                      Gives shutdown cause -128.
                      Seem to work fine in SMC bypass.
                      Same shutdown happens with disconnected TP/KB/KBLED/CAM.
                      Observations:
                      - SMC_RESET_L - when pulled down - plug goes orange/green and...
                      10-11-2022, 12:06 PM
                    • howardc64
                      P502UI-B1E shutdown automatically after 75s followed by power light blinking 15x
                      by howardc64
                      History
                      - Got TV free. Prior owner claims Vizio logo shows up then nothing. He found U202 EEPROM replacement info (I know NickTV says its never EEPROM haha). Lifted 5 pads removing U202 without proper tools and thought thats end of main board. Gave the TV to me.
                      - I repaired U202 pads and connections. Soldered on prior owner purchased aftermarket EEPROM (original EEPROM was tossed). TV boots to VIZIO logo, then goes blank, shutsdown after a min or so and power on light blinks a number of times.
                      - Fixed 2 circa 2015 Vizios before with classical main board...
                      11-28-2020, 04:25 PM
                    • RATIM SIDDIQUE
                      hp fpw50-la-h323p rev 1.0 automatic shutdown after 30 sec, need help
                      by RATIM SIDDIQUE
                      automatic shutdown after 30 sec of display coming
                      do not shutdown without ramstick
                      someone give me idea plz
                      08-20-2024, 03:50 AM
                    • ronelex
                      Acer MS2304 Shutdown when HDD or ODD Present
                      by ronelex
                      Model: Acer MS2304
                      Board Code: 09920-2
                      Issue: Unit Powers On with Display Without HDD or ODD attached
                      When ODD or HDD is present unit powers on then Shutdown it reaches current of 1A that looks like want to boot but it will shutdown
                      Unit wont shutdown when ODD or hdd attach if no ram is attach also
                      I have tried flashing bios, the only different it will not shutdown immediately reaching 1A but eventually will shutdown also
                      05-15-2021, 01:28 AM
                    • IamPritesh
                      Help - Auto starts after 1 minute of shutdown - Dell vegas/turis 15341-1
                      by IamPritesh
                      I have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
                      Some very important points :
                      • Laptop does not auto starts after shutdown if adapter is connected.
                      • It will only auto start after shutdown if the laptop is in BATTERY only mode.
                      • I have tried replacing batteries with a known
                      • if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
                      09-24-2021, 05:01 AM
