Presario 2170 power issue
  • J Riff
    • 9
    Well, here's my rookie dumb question introduction.
    Compaq Presario 2170, its Korean I believe, no English. It booted, into Windows 7 when I first tried it. Found an English language pack and was going to install it, but now it won't start.
    Actually, it starts, the lights come on, tho I cant see a blink code.. then shuts off, and tries to start again. The fan powers up, shuts off, and it does this over and over and won't turn off until unplugged and battery removed.
    I have it apart, and have tools and a DMM, just wondering where to start.
  • wideon
    • Feb 2013
    • 15
    • england
    Re: Presario 2170 power issue
    try and take out the ram and give it a clean also check the fans are not clogged up with dirt and dust try that
    just reread your post scrap that idea is there voltage coming in via the dc jack
    • selldoor
      Slow Learner
      • 7870
      Remove any removable ram and the hard drive and see how far it gets.
      should obviously stop and report no ram /no drive.
      Replace the ram (1 stick only) and try again - should report no drive
      but can you get into the bios. F1 F2 delete esc or whatever?
      With all the bits back no power connected remove the battery and the cmos battery press the on/off switch - leave a couple of hours - put the cmos and main battery back and try again.
      • J Riff
        • 9
        Took out the HD and ram and put back in one at a time, no change, whether battery is in or out. Fan runs about 5 secs. then restarts. Four blue lights come on, then just the power lite, then won't shut down till unplugged.
        Hit the reset button, no result. The CMOS is hard to get to, could it be a problem?
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          yes. CMOS can be a problem it can caus problems from refusing to load BIOS with a dead CMOS battery, to of my fault the wifi not loading thanks to "android x86" damaging the wifi card configuration in CMOS.
          so check the CMOS battery it shold show anywhere from 3volts to 3.3volts if it is good if not it is bad and you need to get a new CMOS battery.
          Follow the white rabbit.
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            motherboard problem
            • trebo
              • 514
              • Wales, UK
              had a acer that done much the same thing, turned out to be the CPU
              • J Riff
                • 9
                Well thank you all. I took out the CPU and cleaned it. Still wouldn't start. I switched out a ram stick and boom, started right up. So twas both issues I reckon. *
                Now where do these extra screws go ....*
                • J Riff
                  • 9
                  It's back. Tried for weeks to get the OS into English but no cigar.
                  DBanned it, then nothing would install. XP would not copy various files.
                  Got Kubuntu onto it, used UBC and finally got XP on there.
                  Prob is, the keyboard is missing letters. E, I, and others. They just aren't responding, though a remote keyboard works fine. Been thru all the obvious CP settings, starting to wonder if it is a connection problem.
                  Anyone know a freeware prog that will detect and/or correct the keyboard layout?
                  • sparker1
                    • Sep 2011
                    • 343
                    If a usb keyboard works fine wouldn't it just be a problem with the inbuilt keyboard? They can't be repaired but can be replaced cheaply.
                    • J Riff
                      • 9
                      I read up on Compaq keyboard connection issues, the ribbon cable, but this thing had so many issues - its an asian machine, couldn't even find a language pack for it, so I thought perhaps it was just the wrong settings, the wrong layout. Can't think of a way to test that.
                      Been thru the HP online upgrades, no help there.
                      Found this machine in a gobbage can and it runs great now, after 130 updates, ceptin' for the KB issue. TX for any help in advance.
                      • J Riff
                        • 9
                        Aha, I thinks, after wiggling the cable and having a few letters return - it is the cable after all. Reattached it, firmly, and guess what? No KB OR mouse.
                        The connections look fine... I don't get it. Going to try another KB if I can find one.
                        There were three (3) screws left over when I reassembled this thing a few months back, wonder if that could affect it?
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • justice171
                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                          by justice171
                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                          1. Verified that all critical voltages are present:
                            • 3.3V and 5V are always present if DC is plugged.
                            • 1.8V on the BIOS chip is present.
                          2. Checked the power button functionality:
                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                            • Confirmed connectivity is intact, ruling out issues
                          11-26-2024, 12:39 AM
                        • claws77
                          lenovo flex 5 14itl05 power sequence issue
                          by claws77
                          hi guys, my motherboard will not start no matter what
                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                          but rest nothing happens no sign of life.
                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                          i have no knowledge of motherboards ....
                          10-20-2024, 02:48 PM
                        • yaya3gmax
                          Laptop Power Issue – Works on Battery, Fails on Adapter Load
                          by yaya3gmax
                          Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                          Symptoms:
                          • Laptop works normally on a pre-charged battery.
                          • Battery does not charge when adapter is connected.
                          • Without battery:
                            • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                            • Speakers “pop” when power cut occurs indicating harsh sutdown.
                            • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                          08-21-2025, 07:16 AM
                        • SuperJames
                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                          by SuperJames
                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                          Specs
                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                          Backstory
                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                          10-23-2023, 04:09 PM
