Hello guys, i have dv6000 at3 mainboard, the laptop has no power. i check the VIN there is no output.I already replaced the charging IC Maxim 8724E still no VIN, i check all the PIN except PIN11-ACOK# no voltage, can somebody help me because im new chip level repairing.. I hope somebody can help to fixed this problem..thanks..
Hp dv6000 no power
Tags: None
Re: Hp dv6000 no power
How possible to get 3 and 5 volts when VIN has no voltage, this is between the dc jack to PQ1 mosfet and L1 inductor which provide voltage to 3 and 5v. By the way i tried to used battery and it worked with battery not on ac adapter. My ac adapter is working properly.I replace all mosfet around the charging ic but still no VIN out. one problem I check the voltage gate at PIN4 in mosfet PQ3 there is 2v and on resistor PR182-4v PR183-30v and in charging IC pin11 ACOK-0v. here i provide a schematic diagram..Attached Filesif you find these attachements useful please consider making a small donation to the site
I already change the mosfet PQ62 but still no VIN out, a measure the voltage the pins of PQ2 pin1-19V, Pin 2,4,5,6-4v, i measure the voltage across the of PD20 -pin1-19V, PIN2-2V but the voltage across Pin is came from VH28 which is 30VComment
[QUOTE=siddiq;296604]Try changing PQ40 if you haven't done so already.[/QUOTE
i've done already, now my problem is pin10 of the charging ic before there is 3v now 0V pin11 before 0v now 5v and VH28 before 30v now 2VComment
actually i short the pin 1 and 8 the laptop is working but the battery is not charging, it means that i have a problem only in ac adaptor side.Comment
yes, all the charger are original i used 18.5v and 19v charger, and im 100% sure that is not charger problem. my problem is the gate voltage at PQ61 is only 2v this one should be at 5v-12vComment
Also check resistor 193. Max 8724 should have voltage like this:
pins
1=19v
2=5v
3=2.3v
4=4v
5=0
6=0
7=0
8=3.3v
9=0
10=3.3v
11=.3v
12=3.3v
13=0
14=0
15=5.3v
16=.13v
17=1.6v
18=.13v
19=.13v
20=0
21=0
22=5.3v
23=.13v
24=5.10v
25=.13v
26=19v
27=19v
28=0Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
