Hello guys, i have dv6000 at3 mainboard, the laptop has no power. i check the VIN there is no output.I already replaced the charging IC Maxim 8724E still no VIN, i check all the PIN except PIN11-ACOK# no voltage, can somebody help me because im new chip level repairing.. I hope somebody can help to fixed this problem..thanks..
Hp dv6000 no power
Tags: None
Re: Hp dv6000 no power
Attached FilesComment
I already change the mosfet PQ62 but still no VIN out, a measure the voltage the pins of PQ2 pin1-19V, Pin 2,4,5,6-4v, i measure the voltage across the of PD20 -pin1-19V, PIN2-2V but the voltage across Pin is came from VH28 which is 30VComment
[QUOTE=siddiq;296604]Try changing PQ40 if you haven't done so already.[/QUOTE
i've done already, now my problem is pin10 of the charging ic before there is 3v now 0V pin11 before 0v now 5v and VH28 before 30v now 2VComment
actually i short the pin 1 and 8 the laptop is working but the battery is not charging, it means that i have a problem only in ac adaptor side.Comment
yes, all the charger are original i used 18.5v and 19v charger, and im 100% sure that is not charger problem. my problem is the gate voltage at PQ61 is only 2v this one should be at 5v-12vComment
Also check resistor 193. Max 8724 should have voltage like this:
pins
1=19v
2=5v
3=2.3v
4=4v
5=0
6=0
7=0
8=3.3v
9=0
10=3.3v
11=.3v
12=3.3v
13=0
14=0
15=5.3v
16=.13v
17=1.6v
18=.13v
19=.13v
20=0
21=0
22=5.3v
23=.13v
24=5.10v
25=.13v
26=19v
27=19v
28=0Comment
