Weird problem with ACER 5920G
  • eniac22
    • Jun 2012
    • 124
    • Greece
    I am having a strange problem with an acer 5920G, if i leave the laptop a day without battery and power will be open normal by pressing the power button, but if i make shutdown or make a restart i have to wait a day to power up again
    I changed the power button board but doing the same
    Does anyone have any idea;
  • lord
    • May 2011
    • 319
    • Croatia
    Re: Weird problem with ACER 5920G
    You will have to do u multimeter test when the laptop doesn't work.
    Does it turn on but doesn't have picture or it is dead completely?
    • eniac22
      • Jun 2012
      • 124
      • Greece
      No, it is dead complete, the charging led is on
      • lord
        • May 2011
        • 319
        • Croatia
        Measure the bit coils for voltage and resistance to ground.
        • eniac22
          • Jun 2012
          • 124
          • Greece
          The problem is only when i connect the power supply, if i have a charged battery on the laptop is work OK.
          I will try to measure the coils
          • valiant007
            Comp Technician
            • Dec 2012
            • 44
            • philippines
            try using another charger. maybe your charger is faulty.
            _________________________________________________________________
            Free Computer Service!!!!!!!!!
            If We can´t Fix the problem.
            • eniac22
              • Jun 2012
              • 124
              • Greece
              finally is working ok, maybe was from moisture from contact cleaner i use to remove dust
              • Destroyer-Br
                [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                by Destroyer-Br
                I'm working on an Acer Nitro 5 unit with the following specs:
                • Motherboard: LA-J871P Rev: 1B
                • Model: Acer AN515-55-59MT
                • S/N: NHQ7JAL00403906A973400
                • SNID: 03902728734
                Initial Issue
                The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                04-17-2025, 08:18 PM
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Duranitron
                Asus x512dk rev 2.1 power on problem
                by Duranitron
                When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                11-26-2024, 10:22 PM
              • Bonaventure Vigil
                ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                by Bonaventure Vigil
                Dear All,
                Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                12-12-2024, 10:22 AM
              • justice171
                Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                by justice171
                I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                1. Verified that all critical voltages are present:
                  • 3.3V and 5V are always present if DC is plugged.
                  • 1.8V on the BIOS chip is present.
                2. Checked the power button functionality:
                  • When pressed, the voltage drops to 0V, indicating the button is functional.
                3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                  • Confirmed connectivity is intact, ruling out issues
                11-26-2024, 12:39 AM
