Toshiba A200 random shutdown
  • ahmtmrt
    toshiba a200 shuts down randomly and can not resolve this problem, Can you help please?
  • Lykos
    • Oct 2012
    • 24
    • Greece
    Re: Toshiba A200 random shutdown
    It shuts down completely or restarts?
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      You need to give more info. Is it after running for a while or right when you turn it on? If you're going to upload pics you should use the attachments option that way they are easier to view. What I always do if it's shutting down after it's been running a while is check for a wall of dust on the heatsink, it causes lots of laptops to overheat and shutdown....I've seen it so bad that a Celeron laptop idled at 77C and put a little load on it and it hit 100C in no time! Toshiba doesn't seem to have very well designed thermal solutions either, especially if they have an AMD processor, thankfully yours doesn't.
      • c_hegge
        • Sep 2009
        • 5219
        Also, does the fan rev before it shuts off?
        • Taxman
          • Nov 2012
          • 45
          I recently looked at a laptop (Toshiba Satellite L500) that was randomly shutting down at first then always shutting down before completing startup.
          As a previous respondent said, a dirty fan was the culprit.
          The fan had a thick piece of gathered dust that had knitted together (like the stuff you remove from the filter in your tumble dryer). I assume it had been jamming the fan and causing the system to shut down to prevent overheating.
          Either way, clearing the fan, cleared the problem.
          • gabik111
            ORD spotter
            • 142
            • USA / Poland
            I got the same issue in A205. It happened twice before to me. It just shut down during work but only when was working on battery. I think my issue is the weak battery (it just shot down when was 43% of energy left) but those are my thoughts , or some bad capacitor (it was dual capacitor replaced near CPU two years ago).
            Did not find any problems on mobo , got cooling system clear and neat , fresh thermal compound.
            Laptops and computers repair.
            • Chieftain
              • May 2016
              • 72
              • Greece
              This is a VGA driver problem. If you use the "Windows update vga driver, VGA reads wrong temperatures from chip , so it spins the fan in lower speeds. Use the official VGA drivers. If the proplem continues... reball your VGA or replace it...
              • rievax_60
                • May 2012
                • 897
                • australia
                Years ago I had an A200 model that would randomly restart or restart when the main board was physically stressed.
                I found pin 1 (EN) on the VCORE regulator IC, ADP3208, going open circuit. I thought that this would have to be a one off occurrence.
                Lately I met another A200 with exactly the same fault.
                To confirm, I heated the IC while doing a DMM diode test on the lower input protection diode on pin 1. I got a fluctuating reading.
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  After all of these years, I'm still using some of my Satellite A200 laptops.
                  Mainly the models that use the Intel 965 chipset.
                  I have just repaired the 2nd one that was randomly shutting off.
                  I fixed both by replacing a temperature sensing IC near the CPU.
                  The IC is marked "G784".
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    offcourse it is NEC Tokin capacitor problem. u must replace it with 4x330 capacitors.
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      The NEC Tokin capacitors have been replaced in all of my A200 laptops years ago. I mainly use ceramic caps.
                      I'm totally certain that the temperature sensor ICs were the cause of this recent shut off symptom, not restarting.
                        Toshiba Satellite Pro A200-1KQ Specification for Upgrade or Repair
                        This specification for the Toshiba Satellite Pro A200-1KQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1KQ boardview and A200-1KQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                        09-06-2024, 05:27 AM
                        Toshiba Satellite Pro A200-1H4 Specification for Upgrade or Repair
                        This specification for the Toshiba Satellite Pro A200-1H4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1H4 boardview and A200-1H4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                        Toshiba Satellite Pro A200-1K4 Specification for Upgrade or Repair
                        This specification for the Toshiba Satellite Pro A200-1K4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1K4 boardview and A200-1K4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                        Toshiba Satellite Pro A200-16B Specification for Upgrade or Repair
                        This specification for the Toshiba Satellite Pro A200-16B can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-16B boardview and A200-16B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                        Toshiba Satellite Pro A200-1MV Specification for Upgrade or Repair
                        This specification for the Toshiba Satellite Pro A200-1MV can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1MV boardview and A200-1MV schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
