Toshiba L510 power problem
  • bsant79
    • Oct 2012
    • 17
    • indonesia
    I have my L510 have problemm,
    1. its only can on by battery plug in ( can only on by battery ) its can't power on by dc power adapter,,
    2. its power on would last only 5 minute then its power off its self
    need help here ,, i'm very appreciate for any idea could be its bios or hardware trouble..
    thanks alot ( indonesia here)
  • bsant79
    • Oct 2012
    • 17
    • indonesia
    Re: Toshiba L510 power problem
    anyone have idea
    • lord
      • May 2011
      • 319
      • Croatia
      I think you have 2 issues. First one is the battery controller or some mosfet near power on, and the other is turning off after 5 min. Did you measure the temp before it shuts down?
      • bsant79
        • Oct 2012
        • 17
        • indonesia
        yes i have 2 issue here,,, no have not measure the temp yet,, what is the normal temp exactly its?
        ( soorry i just came back from my home town.. thanks )
        • dycc
          Vision
          • Nov 2011
          • 625
          • Côte d'Ivoire
          i have resolved this kind of issue one day . but for me it was ISL6251 (charging circuit)
          . can you share a view of your board here , it will be very easy four us to give you some guidelines about this trouble .
          • xaviero1412
            • Apr 2009
            • 56
            classic symptom for toshiba series
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Check the megathread on this issue.
              Primarily, it is caused by a bad capacitor made by 'NEC-TOKIN'
              Hope this helps you!
              -Ben
              Muh-soggy-knee
              • bsant79
                • Oct 2012
                • 17
                • indonesia
                mainboard picture hannstar
                • bsant79
                  • Oct 2012
                  • 17
                  • indonesia
                  maybe it was ISL6251 ( i'll try it,, thank ,, i will inform later the result )
                  picture uploaded,,
                  -Ben
                  already try it but still not solving the problemm,, thanks anyway,, any other issue???
                  • remacomp
                    • Oct 2012
                    • 8
                    • Rep.Srpska
                    i had same problem
                    problem is with nec/tokin which is located under cpu (other side).
                    i changed it and laptop works fine for month or two and same problem again.
                    this time i changed it with 4 capacitors and it works more than 6 months.
                    • bsant79
                      • Oct 2012
                      • 17
                      • indonesia
                      Originally posted by remacomp
                      i had same problem
                      please can u share some picture that u do,, thanks a lot
                      • trebo
                        • 514
                        • Wales, UK
                        @ bsant79
                        Go to this Badcaps Thread.
                        https://www.badcaps.net/forum/showth...t=8991&page=21
                        It has all the pictures and information that you require there, on that problem, its a megathread.
                        If you need more help, then please do ask
                        • bsant79
                          • Oct 2012
                          • 17
                          • indonesia
                          Originally posted by trebo
                          @ bsant79
                          I think its different base trouble...mine is only can ON FOR 5 MINUTE !!!!! N I ALREADY TRY REPLACE THAT NEC/TOKIN EO128 WITH SMD CAP 4 unit 330uf
                          Thank s,,,
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Thank s,,,
                            Is the CPU and GPU getting enough cooling?
                            You might have a bad joint somewhere, which could be heating up and disconnecting, making your computer shut down.
                            Muh-soggy-knee
                            • bsant79
                              • Oct 2012
                              • 17
                              • indonesia
                              In 3 time boot try its getting warm CPU n GPU
                              • bsant79
                                • Oct 2012
                                • 17
                                • indonesia
                                thank u all ,,, i found the cause of the trouble " IT WAS MIC OUT PUT SORTING / before socket mic on mainboard there is cap that not good " its solvedddd
                                one again thank u alll
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  WOW, good job!
                                  Congrats! I bet it took a while to find that shorted cap!
                                  -Ben
                                  Muh-soggy-knee
                                  • bsant79
                                    • Oct 2012
                                    • 17
                                    • indonesia
                                    WOW, good job!
                                    -Ben
                                    Yes .. ben7 its long observe... i try to trace track i/o device mainboard. So finally found that error
                                    • bsant79
                                      • Oct 2012
                                      • 17
                                      • indonesia
                                      BUT now after that i got new error,,, win 7 status bar show " plugged in, charging " but after one hour batt precentage still not up just stay its precentage... any idea what the problem???
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        Hm, does the power jack plug get hot? Mine (an L645D) started to give error codes, and the battery didn't charge all the way - the power jack was very hot, which told me that there is a bad connection. The wires that are soldered to the power jack were broken, and had arced and they were discolored. Re soldered the wires, and all is good
                                        But I don't know if this could be your problem or not.
                                        Muh-soggy-knee
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Duranitron
                                          Asus x512dk rev 2.1 power on problem
                                          by Duranitron
                                          When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                          Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                          11-26-2024, 10:22 PM
                                        • EazyBone
                                          LG OLED55C9PUA power problem
                                          by EazyBone
                                          Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                                          Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                                          I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                                          The power supply to t con is different story.
                                          This...
                                          06-23-2023, 07:43 AM
                                        • Dr.d
                                          Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                          by Dr.d
                                          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                          04-05-2024, 11:48 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
