It powers on , fan spins but after a few seconds restarts and caps/num lock flash 1 time with 3 seconds interval . Could it be cpu as hp says or vga/southbridge ? Anyone has experience with this model and error ?
GPU is out. Reflow GPU and SouthBridge to be sure.
I think best way to make it work is replace GPU or reball it with leaded balls. But if you reflew it and it still does not work rather I can say GPU needs to be replaced . Soldering pads separeted from GPU like it happened in this faulty series and reflow does not work.
After you replace it remeber to reflow GPU RAM chips because you can get artifacts.
Reflowed but the same happens. Starts up , fan spins for a second and then caps/num flashes one time every 3-4 seconds.
Did you melt the balls from under? Light reflow won't work, reflow it, but melt the balls. If you know how to reball, it would be better, but do not use heat gun, use the proper machine.
