HP pavilion dv7
    HP pavilion dv7
    It powers on , fan spins but after a few seconds restarts and caps/num lock flash 1 time with 3 seconds interval . Could it be cpu as hp says or vga/southbridge ? Anyone has experience with this model and error ?
    Re: HP pavilion dv7
    try replacing cpu
      Re: HP pavilion dv7
      GPU is out. Reflow GPU and SouthBridge to be sure.
      Could also signify bad ram port.
        Re: HP pavilion dv7
        I have most of them repaired
        Each platform has its own fault.
        Your platform is?
        CPU?
        Gpu?
          Re: HP pavilion dv7
          exact model is 1030ev . I don't have any spare cpu to test so I will try reflowing gpu and see what happens .
            Re: HP pavilion dv7
            Likely GPU (G96-630)
            Try to see if you have on the external monitor picture
              Re: HP pavilion dv7
              Reflowed but the same happens. Starts up , fan spins for a second and then caps/num flashes one time every 3-4 seconds.
                Re: HP pavilion dv7
                I found a similar proccessor and tried it but the same error. I'll try reflowing northbridge and then I'll give up .
                  Re: HP pavilion dv7
                  Have you tryed the "Blind" Bios recovery proceedure?
                  I'm guessing a corrupt bios.
                    Re: HP pavilion dv7
                    Unfortunately I don't have it any more to try . Thanks for the suggestion
                      Re: HP pavilion dv7
                      I think best way to make it work is replace GPU or reball it with leaded balls. But if you reflew it and it still does not work rather I can say GPU needs to be replaced . Soldering pads separeted from GPU like it happened in this faulty series and reflow does not work.
                      After you replace it remeber to reflow GPU RAM chips because you can get artifacts.
                      Laptops and computers repair.
                        Re: HP pavilion dv7
                        if 3 seconds interval, try replacing memory
                        http://h10025.www1.hp.com/ewfrf/wc/d...t=3860630#N215
                        its what hp says
                          Re: HP pavilion dv7
                          did anybody have bios of hp pavilion dv7-6858sf ...beats audio.
                            Re: HP pavilion dv7
                            Did you melt the balls from under? Light reflow won't work, reflow it, but melt the balls. If you know how to reball, it would be better, but do not use heat gun, use the proper machine.
