Hp nc6220
  • siddique
    • Mar 2012
    • 18
    • india
    Hp nc6220
    I have hp nc6220 laptop , power oning time video ok but not changing bios functions&the time displaying smart card insert
    any ideas?
  • lord
    • May 2011
    • 319
    • Croatia
    Re: Hp nc6220
    I dont understand what is wrong.
    • siddique
      • Mar 2012
      • 18
      • india
      Re: Hp nc6220
      the laptop display ok but not bootting operating sysytem&sowying smart card inserted
      help me............
      • lord
        • May 2011
        • 319
        • Croatia
        Re: Hp nc6220
        Try another HDD
        • siddique
          • Mar 2012
          • 18
          • india
          Re: Hp nc6220
          this is board side prolem , i have check hdd & odd
          • lord
            • May 2011
            • 319
            • Croatia
            Re: Hp nc6220
            Did you reball the south bridge?
            • lucco85
              • Feb 2012
              • 20
              • Hrvatska
              Re: Hp nc6220
              The most common failure in this series is the SB.(FW82801FBM)
              It is best to replace with new one
              • titomno2
                Gaming Laptop Zephyrus S17 TFT not detected every time !
                by titomno2
                Hi guys,
                I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                Then the screen won't work for a long period of time.
                If I wait 1 or 2 hours it work again most of the time.
                When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                01-19-2025, 08:27 AM
              • Francesc V.
                Technics SA-AX530 in protected mode. Overload message
                by Francesc V.
                I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
                I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
                I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
                (Pin 13 goes through...
                11-18-2024, 12:39 AM
              • flat-earther
                Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                by flat-earther
                I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                I have opened the camera and I think there is enough room to add something inside to accomplish this:
                The camera is powered by a 3.7V nominal single cell lithium ion battery.
                So I need to connect another battery in...
                06-08-2025, 02:00 AM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • OscarAV
                HP Pavilion dm4-1065dx long time to get the power led on
                by OscarAV
                I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
                I have made a quick search for my laptop but I have not seen anything similar.
                I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
                09-23-2024, 05:53 PM
