Hp compaq cq60 keyboard and touchpad not working
  • raj2006
    • 20
    hi
    i have an cq60 Intel warroir2 laptop motherboard,in windows usb keyboard is working,but internal keyboard is not working,and also touch pad is not working.
    tp on/off but changed led status on laptop.also if i pressed Fn + f7 or f8 ..brightness up down is working.things i have checked but (no luck) are following.
    1.Changed keyboard with new one.
    2.cleared cmos.
    3.Reset motherboard by pressing power btn without batt and power adapter .
    4.Traced keyboard tracks and remove all capacitor network rc1 to rc6.
    5.Replaced Winbond wpce773la with new one.
    6.i have checked bios by reprogramming with this file 360BF65.FD available on hp.
    7.checked some components around wpce733.
    Please help in understanding what is gone wrong this motherboard .
    i will be very much thankful .
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Hp compaq cq60 keyboard and touchpad not working
    Clean the connector on the mobo.
    • raj2006
      • 20
      Thanks for replying.
      Connectors and connections looks good.and also if there was problem some keys are also working or touch pad must work.but both keyboard and touch pad are not working.
      Does anybody faces that problem in this or other laptop? please share the experience .i will be great full to you.
      • magistertc
        • Feb 2006
        • 25
        Had this problem last year, built-in keyboard and touchpad would not work and could not re-install the drivers. BUT it would work with USB keyboard and touchpad. IIRC it was an Acer laptop....
        Ran SFC /scannow and dug through the log - found possible corruption error for one obscure file (wdf01000.sys in this case). I got a copy from another machine, had to futz with the permissions to do the replacement, and that took care of it.
        /* edit Built-in keyboard would work during boot, just not with windows */
        You may be at the point where OS reinstall is necessary. Good Luck.
        • raj2006
          • 20
          Thanks for sharing this,but situation is little different here,i tried to enter cmos setup but i couldn't able to because internal keyboard is not working and usb were working at the time of windows ,not at POST .so i when i cleared cmos i even can't able to boot the laptop because of "cmos check sum error Press F1 or F10 to continue" message on POST. All this show that problem is in hardware but final cause is little far from us.
          • popeye
            • May 2011
            • 155
            Originally posted by raj2006
            hi
            2.cleared cmos.
            Hi
            Have you checked that the cmos battery is at aleast 3v?
            if yes do you have 3v at winbond ic also clk signal
            on those mb there are track breaks that you could easly un solder by mistake! you will need a schematic top go deep into this mb.
            good luck
            • User555111
              A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
              by User555111
              Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
              02-05-2024, 08:16 AM
            • B2L_Repairs
              Macbook A1706 touchpad and keyboard not working. Please help
              by B2L_Repairs
              Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
              10-09-2023, 04:56 AM
            • fichamba
              MSI GL75 Leopard keyboard (almost) not working - HELP
              by fichamba
              Hello everybody:
              Let me put all the laptop's info before describing the problem:
              BRAND: MSI
              MODEL No.: MS-17E7
              SKU: GL75 Leopard 10SEK-261XES-BB71075H16GXXDXX
              MoBo: MS-17E71 VER. 1.0
              This laptop arrived to fix the broken left hinge, due to a hit. The hinge was repaired, and when I went to check it out, everything worked well, but I observed certain artifacts (mainly random lines) in the screen.So I decided to remove the screen bezel again, and I saw certain damage to the main LCD harness.
              This time I also observed that the right...
              10-09-2024, 04:53 PM
              HP Compaq Compaq 15-s006tu Notebook 15 Specification for Upgrade or Repair
              This specification for the HP Compaq Compaq 15-s006tu Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Compaq 15-s006tu boardview and Compaq 15-s006tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
              09-06-2024, 05:27 AM
            • Vliegenier04
              Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
              by Vliegenier04
              Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
              I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
              Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
              06-16-2025, 12:03 PM
