Lenovo n500 doesn't show video
  • nucleus
    • May 2012
    • 64
    • Montenegro
    I got this Lenovo n500, when pres power button it starts but nothing on display. It charges ok, CPU is heating, lamps flashing.
    Does anyone have experience on this model? Any known issue with this simptoms?
  • mattbrad2
    • Jan 2011
    • 122
    Re: Lenovo n500 doesn't show video
    You get anything on an external display? Is this the Intel GMA or nVidia 9300 model?
    • nucleus
      • May 2012
      • 64
      • Montenegro
      Nothing on external display, Intel GMA
      • mattbrad2
        • Jan 2011
        • 122
        Tried replacing memory?
        • t.j.
          • Apr 2010
          • 383
          • canada
          when ya hooked up external display! did ya hit fn/f4 to set to external?
          • bluestone
            • Jun 2011
            • 343
            • Ghana
            I have the same problem with my lenovo n500, i tried different ram and cpu still no sign, connected external display but no help, i think it is problem with the mother board. chip or ic issue
            • bluestone
              • Jun 2011
              • 343
              • Ghana
              Anyone come in contact with this kind of problem, please help
              • RepairNooB
                • Jul 2012
                • Singapore
                hi, i would advice you to strip down the laptop. look for the Graphic Chip and use a hot air gun and apply heat for about a min.. then apply good thermal paste and try again.. Problem can be sloved !good luck!
                Heat - 230 Degrees
                • nucleus
                  • May 2012
                  • 64
                  • Montenegro
                  It is definitely a motherboard problem, just wondering if someone else had dealt with something similar.
                  I checked many voltages and they are ok ( 5v, 3v, 1.8v, 1.5v, CPU_core, VGA_core)
                  I will try with reflow of intel chipset (ac82gl40) which is VGA also.
                  Does someone know does they die more often or just need reflow????
                  • aaroncm
                    No video when trying to unlock Lenovo T420
                    by aaroncm
                    Hi guys,
                    Today I pulled 5 Lenovo T420 laptops out of a bin at the rubbish tip, and they're old school laptops and they're all locked with a supervisor password.
                    In the past I've unlocked similar Lenovo laptops, often I used the trick of shorting a few pins together on the chip on boot to get into the GUI and overwrite the config but it doesn't look like that is working with these laptops. I guess Lenovo fixed that trick? I have unlocked some other HP laptops by reading the chip, running a patch and re-writing back.
                    But I can't work out these T420...
                    11-11-2023, 10:05 AM
                  • coasterghost
                    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                    by coasterghost
                    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                    System Hardware:
                    Processor: AMD Ryzen 7 PRO 5850U
                    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                    09-08-2025, 10:46 PM
                  • salvador17
                    Lenovo yoga 6 13ALC6 does not show video
                    by salvador17
                    Hello, it is to request help, my lenovo turns on but does not show video. I have already checked all the voltages on the motherboard and everything seems to be correct. Apparently it's a problem in the Bios but I can't find another bios to correct. I wonder if it is possible to repair the same Bios?
                    01-25-2023, 12:40 PM
                    HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                    This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                    09-12-2024, 02:00 PM
                  • alro7779
                    HP 11 Stream laptop DAYOHGMB6C1 REV:C doesn't show video at all!
                    by alro7779
                    Hello, there!
                    The problem with this laptop is that it does not show video at all, even if I connect an external HDMI screen device to its port.
                    I got it disassembled, and first of all it does have its VDC in (19.81). I checked the 5 inductors having the charger plugged in, and the voltage readings are:
                    TURNED OFF (without pressing the power button)
                    1: 9.07 VDC
                    2 to 5: 0 VDC
                    TURNED ON (after pressing the power button)
                    1: 9.04 VDC
                    2: 1.203 VDC
                    3: 0.813 VDC
                    4: 3.403 VDC
                    5: 5.133 VDC
                    I'm not quite sure if...
                    05-19-2025, 09:27 AM
