black screen
  • pit2121
    • Feb 2012
    black screen
    need help my gateway mx6421 sarts up with black screen thanks
  • nucleus
    • May 2012
    • 64
    • Montenegro
    Re: black screen
    connect on external display, if there is no picture it could be anything from memmory to motherboard. if it has picture on external display your diplay panel is broken
    • pit2121
      • Feb 2012
      Re: black screen
      thanks it works on external anyway to repair it and thanks for your respond
      • HTR-Informatique
        Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
        by HTR-Informatique
        YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
        I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
        On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
        I also changed the screen because the PC fell and the screen was broken.
        I changed the battery with a new and original battery.
        I also had corrosion/oxidation on the...
        02-09-2025, 06:51 AM
      • survivalbloke
        HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
        by survivalbloke
        SN: 8CG0213H8W
        ProdID 3C311UA
        This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
        05-08-2025, 12:21 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • DaniK
        Acer Aspire E5-574-52RH - black screen
        by DaniK
        I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
        Laptop came in for a SSD upgrade, took everything apart to install the SSD.
        Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
        Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
        The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
        Symptoms are:
        - random black screen after displaying Acer logo...
        02-21-2024, 06:27 AM
      • turmix
        AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
        by turmix
        Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
        The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
        At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
        During another reassembly, I made a mistake, and...
        01-29-2024, 03:48 AM
