Hp dv5 504640-001
  • marcellodj
    • Nov 2010
    • 99
    Hp dv5 504640-001
    The unit was killed by customer inverting polarity with an external oem supply; now no power led and no signs of life.
    I found 19v,3v and 5v in several zones, and 3v on pwr btn, but would know a good point to start for.
  • Nocta
    • Mar 2012
    • 117
    • Argentina
    Re: Hp dv5 504640-001
    Could you please upload pictures of the motherboard? From both sides.
    Please, attach them don't post them inline.
    • b700029
      Banned
      • Sep 2010
      • 640
      Start looking in the 5VSB/3.3VSB circuits.
      Is it a Quanta QT8 or other motherboard model? You can try finding the schematic if you know this.
      • marcellodj
        • Nov 2010
        • 99
        Hello, is QUANTA QT6, schematic found ,where to start for?
        • b700029
          Banned
          • Sep 2010
          • 640
          Look for the standby voltages first.
          • marcellodj
            • Nov 2010
            • 99
            While looking voltages (all seems good), found ENE KB3926 getting very hot, will try to replace and keep forum updated.btw happy easter to all.--m
            • b700029
              Banned
              • Sep 2010
              • 640
              That's the embedded controller. If you replace it you will need to reflash the firmware.
              • marcellodj
                • Nov 2010
                • 99
                Reflashing is needed also if i use the same part?
                • mecha1166
                  Anyone here fix a tv and customer cracks panel when they get it home?
                  by mecha1166
                  About 2 times a year, a customer will do this. We fix the tv, put it on test play, and customer sees it working. They see me pull power and video wire. Sometimes I pick up tv, right in front of them, and carry it out to their vehicle while they are next to me. I set it in their tv gently, and tell them the tv is very fragile, be careful with it. I let them close the door/trunk. That day, or a few days later, they tell me there is a crack inside the tv. Normally I tell them transportation is their responsibility and normally that is the end of it. Has anyone had a customer that was not buying this...
                  03-29-2024, 11:27 AM
                • Dev Goose
                  Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
                  by Dev Goose
                  Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
                  What Happened
                  The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
                  12-13-2024, 03:13 AM
                • howardc64
                  Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                  by howardc64
                  Problem
                  Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                  Model & Board Pics
                  Conflicting Spec
                  Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                  https://www.shopjimmy.com/vizio-gj-2k1...
                  10-10-2024, 01:16 PM
                • DAVEMAC02
                  Inverting op amp circuit
                  by DAVEMAC02
                  Yamaha Stagepas 300 pa system. I have a problem with the attached inverting op amp circuit. I have no output at pin 1 of the B amp. I have audio across cap 221. I've checked resistancr values and grounds and are all ok. I've checked for diode function on IC204 pins 2 & 3 and check ok. I don't know what other components are in IC204 and how to check. There is FET Q208 & Transistor Q205 and I don't their purpose in the circuit. I don't think IC204 is bad , but I don't know how to prove it is good or bad. Don't want to replace it if it is good as I will still have the problem. Need...
                  09-30-2024, 12:13 PM
                • Kervin Mathumbu
                  Asus E410 only works on battery after reverse polarity
                  by Kervin Mathumbu
                  Hi everyone. Fixed my AC and despite trying to be extra careful, I reversed polarity and got a notable pop sound. Now the PC will only work on battery. Windows still shows the battery as charging but the count actually goes down until empty (I have two of the same laptops).
                  I have board R3.0 so the schematics on another thread here do not match mine. I have tested the BQ charge IC and my pin 1, 2 and 3 have 3.35v each - instead of 18v or 19v. Could this be a bad BQ IC or capacitor? Any thoughtful advise sould be greatly appreciated.
                  Mobo shows no visible sign of a fried...
                  07-15-2024, 11:26 AM
