Dell Inspiron 1501 Win7 no toolbar preview or tooltips
  • pol098
    • Sep 2011
    • 18
    This is a very weird problem and workaround I'd like to find some explanation for. The workaround I'm using is OK, I'm not seeking a workaround but understanding (a proper, permanent, solution would be nice). It's probably not a capacitor problem as such. Dell Inspiron 1501 laptop, latest (last) BIOS. AMD Turion CPU. Windows 7/32 not officially supported but works fine in all other ways.
    Under Win7/32 the machine is set up to display a preview of open programs by hovering over the toolbar icon. This is actually essential, as right-clicking the preview is the only way to access some context menus. The problem and workaround has been documented; it is specific to this and possibly a few other Dell laptop computers. Problem: the preview is not displayed; and tooltips in general are displayed for less than a second, rather than as long as hovered over. This problem happens after months or years of use, and is persistent. Only workaround: disconnect power and remove battery. Hold down "on" switch for 15" (I'm not sure if holding switch is essential, it's difficult to check details of a problem which occurs at intervals of months). Reconnect power, and the preview and tooltips are back to normal for weeks or months (I have had to do this just twice, the first time when the machine was perhaps 4 years old, some months after installing Win 7). Simply powering down and restarting does not work. I am virtually certain that there is no malware issue - machine works perfectly in other ways, many malware checkers find nothing.
    I would have said that this is impossible and can't happen. There might be a memory location which takes on contents that cause the problem, and is never written to or erased, but whose contents are preserved, once set, so long as there is standby power. Can anybody cast any light on this odd problem? I can't run any tests in the problem state as it's been working OK for months since last fix. Thanks
  • smason
    • 1652
    Re: Dell Inspiron 1501 Win7 no toolbar preview or tooltips
    That was my first thought as well. Is it possible one of the Dell utilities is messing things up? Though since this isn't a factory install you probably don't have 'em. Some of them, the power ones in particular can be a pain in the rear.
    • b700029
      Banned
      • Sep 2010
      • 640
      My guess is there is some weird interaction between the embedded controller and a timer in the chipset. Removing all power sources resets the EC, but if the laptop is off with the battery in, or with only the AC adapter, the EC is still powered.
      • pol098
        • Sep 2011
        • 18
        Originally posted by smason
        ... Is it possible one of the Dell utilities is messing things up? Though since this isn't a factory install you probably don't have 'em.
        Thanks for considering this, there's been no useful discussion elsewhere of what happens. As you say, utilities not installed. But even if they were, NO software that runs at startup (or possible malware) makes sense of this to me. The problem persists even if the machine is switched off fully then switched on again (without removing battery), but goes away if machine is removed from power. These two actions should produce the same result.
        I'd think it was my imagination, expect that there are several reports of the same problem, and I have been thanked by someone badly troubled by this problem to whom I gave the workaround.
        • pol098
          • Sep 2011
          • 18
          Thanks for suggestions. I don't think the EC interaction is something I can sensibly check experimentally, but it makes sense; I think my speculation of a memory location that doesn't get reset is also conceivable (PCs used to have system information stored in RAM locations from, I think, 0x400, though I don't remember the details). BTW, over many years I have sometimes had problems with computers, and other electronic gear, which persisted across a restart, but cleared if the device was left unpowered for a long time. Nothing I've documented, but enough that I don't give up on something until I've left it unpowered, preferably for a few days. Thinking about it, this happened more often with IBM PC-era equipment, haven't had anything like it for a long time.
          • b700029
            Banned
            • Sep 2010
            • 640
            I think that would be the EC's RAM. The other nonvolatile memory is CMOS settings which does remain powered (by the CMOS battery) when the main battery is removed.
            • pol098
              • Sep 2011
              • 18
              That sounds reasonable. My suggestion involves the slightly mystical, but not totally impossible, concept of a conventional memory location whose contents remain stable when switched off, but are cleared when all power is removed - memory which is not formally non-volatile, but actually acts as battery-backed RAM.
              • Hondaman
                Win7 Emulation in Linux
                by Hondaman
                If I install Win7 in VirtualBox or KVM, will Windows be tied to that exact hardware? Can I take the VM and move it to another machine at some point without having to re-activate Win7?
                I bought a replacement board identical to the one Win7 is licensed on. But of course it failed. I have two more identical boards in my basement. Running out of acceptable hardware will not happen for quite a few years, hopefully.
                But I am looking forward to that day when I cannot find any hardware, and I have to use emulation. Does anyone have experience with this?
                07-21-2025, 12:46 AM
              • eccerr0r
                win7 home iso? can I get 10?
                by eccerr0r
                Well I think that I have a GTX660Ti that's dead but I think I should give it one last try with its original OS and drivers: win7 home premium. While I can't stomach using win* of any type (I'm 100% Linux these days) I think I have to give benefit of the doubt to drivers, etc.
                So... I have the original CoA for Win7 home premium and it's an OEM license. And I have the whole computer that the GTX660Ti came in (it was reportedly working too), minus the original hard drive, what could I download and run the machine temporarily to verify the GTX660Ti works with Windows or not?
                09-14-2023, 07:35 AM
              • Hondaman
                Japanese language -- Win7 or Linux Mint?
                by Hondaman
                I ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
                Does anyone have experience...
                09-12-2025, 04:32 AM
              • MikePCS
                UN70NU6900FXZA power cycle, no picture - workaround found
                by MikePCS
                I have a just of warranty 70" Samsung 6-series that out of the blue stopped getting a picture, but I had sound. During the initial outage, the picture came back momentarily and then faded out. The next morning the TV worked on a quick test, but trying it again later it didn't.
                When I have the mainboard disconnected from the power supply, the TV powers on with full LED brightness and stays on
                When I plug the mainboard in, the LEDs go bright-->dim--off -->repeat, while the red status indicator blinks 2x
                WORKAROUND: Unplug one...
                04-29-2022, 03:01 PM
              • Hondaman
                USB problems?
                by Hondaman
                Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                08-12-2024, 03:26 PM
